I'm new here and hope I post in the right forum!
I bought my JM for one year ago everything worked fine (even the hand), but now suddenly the hand have stopped working. This pin is really a favorite so it must be fixed!
I have read "all posts" regading hand issues but I cant find my problem anywhere so I hope someone out there have seen this behaviour before....
It started with the error msg Hand mechanism Y- no progress.
So I checked the magnet and the wires was partly burned so replaced them and thought this woud fix it, but not!
The hand works fine in both X and Y directions when running the selftests, but when I press the blue flipper buttons (Y-directions forward/back) then the hand immidiatly seems to "hang" and stops working.
If I reset the hand by doing a hand test, JM boots up normally without any error msg.
But as soon as the ball gets into the hand and I try to move the hand (by the flipper buttons) in any Y direction the hand stops!
It cant be a wire issue as the hand works when JM runs the hand, must be something else....?
- All switches (X, Y & hand) and the four photo couplers have been checked and they all works.
- I have resolder the Dual relay motor driver board, back of the playfield.
- The magnet works and holds the ball.
- All connectors near the hand have been reseated.
- The both drive nuts/screws seems not to be worn at all.
Dont know where to search anymore and where to look!
Can anyone give some advice, Thanks!
