In the meantime and while waiting for the good soul who will sell me the part I need, the playfield is almost complete. The top plastic has to be cleaned and flattened a little bit, but since it hides a ball, I will put it at the very end. We do not want that ball to jerk around, during the final setting of the playfield. A transistor to replace on the backside, a few wires to be tied up, the ejector walls to be re-installed and the playfield will be ready for the Apron.
I am glad I installed two additional bulbs as the playfield is overall rather dark, even though I used #44 bulbs. I wish I could have installed a third bulb at the very top, between the three top posts, but the metal plate of the vari-target is preventing it. I would have to drill the vari-target plate to make room for the bulb socket, which may not be a good thing to do.
The lightbox is stalled, waiting for the bottom hinge and the finishing of the light board. After spraying two cans of white on the light board, I am still not very happy with the result. That particle board used by Gottlieb is pure "shit" and the damages done by the water are hard to hide. The texture remains rough and uneven and to be a perfectionist, that board would have to be cut and entirely re-done. But who is a perfectionist for an old System 1 machine? I will see what I can get out of it, by sanding it and spraying one more can of white.
The clear coat on the lightbox is very good and so smooth to the touch. I have re-installed the Janin board and the driver board inside as well as the power supply.
I am now working on the insanity of the main cabinet: what a cesspool!! After scrubbing and vacuuming , I realized that the bottom panel was warped by the flow of beers. The stains are disgusting. I have secured the bottom panel with 5 long machine screws and Gorilla glue to the transverse spine. It is now a lot sturdier and I can start painting over that ugliness.
Most likely, I will do a mix of black and white for the inside of the main cabinet.
I cannot leave the wood natural as it is deeply stained and I like the white as it brings light to this part of the machine during the maintenance phases.
Yves
