New! Dark mode!
(Topic ID: 201048)
Y-Splice w/Small Gauge Wire. Best Approach?
By markp99
  • 16 posts
  • 9 Pinsiders participating
  • Latest reply 3 years ago by Fytr
    #1 3 years ago
    I'm looking for some ideas on a better way to produce a Y-splice with small gauge wire (22-26 AWG).
    In this case I am splicing a wire end into an existing length of wire.
    My typical approach is to cut the existing wire at the desired point, strip and tin the ends. Strip the new wire, tin the end. Twist the 3 ends together and solder. Add a bit of heatshrink to cover the new joint.
    This approach seems to work ok, but I wonder about the mechanical strength/durability of the joint. Especially the new wire with its clumsy exit from the heat shrink sleeve.
    Any suggestions for a better Y-Splice? Are crimp options viable? I've used teleco crimp buttons in phone applications; I think they look too ugly to put into a pinball machine. I've seen butt splice crimp sleeves, but for larger gauges. Would these work for a Y-Splice?
    #2 3 years ago
    You want either heat shrink butt connectors that you crimp and hit with heat gun to shrink the wrap. If you have a good set of crimpers this is all you need. I used to do aircraft wiring and this is the way we did it. But we used high dollar crimpers.
    amazon.com link »
    Or get some non-insulated butt splices that you can crimp and then solder and then wrap with shrink wrap.
    amazon.com link »
    Shop around. You can find all gauge sizes.
    #3 3 years ago
    So, can I just use a crimp style butt-splice and add a 3rd wire to accomplish the desired Y-Splice? Wouldn't the extra wire diameter on the "Y" end compromise the crimp connection compared with the single-wired end?
    #4 3 years ago
    Some sort of crimp on may give the cleanest appearance. I like soldered connections. A minimalist approach uses a quality wire stripper to push aside insulation, exposing the conductor for soldering, without cutting the wire. Can fold all the wires back at the joint, if there is enough slack, and slide on a piece of heatshrink, or wrap it up with rubberized tape, or whatever. Not usually too concerned about appearances.
    #5 3 years ago
    Yep, I like the idea of stripping a section of insulation without cutting, but I prefer heat shrink sleeve vs wrap, and really prefer NOT to de-pin or unsolder an end to permit me to slip on a sleeve. Sleeving the folded-over the joint does not pass my OCD test, especially when there are a "few" of these connection in close proximity
    Hmm, a terminal block might actually be ideal in this backbox location. Lots of slack up there... Very tidy result.
    #6 3 years ago
    You want a red squeeze tap connector for 18-22 gauge wire. There is also made one for 22-26 gauge wire as used in telephone hard wiring.
    https://www.homedepot.com/p/Gardner-Bender-22-10-AWG-Tap-Splice-Assortment-5-Case-15-2210/202522123?MERCH=REC-_-PIPHorizontal1_rr-_-202522457-_-202522123-_-N
    They slip over the wire you want to tap into. Then you shove the new wire into the extra hole and squeeze with pliers.
    These are called tap-ins at Radio Shack (they've got the small ones for 22-26 gauge wire in the telephone applications section), and squeeze taps by electricians.
    #7 3 years ago
    Quoted from KenLayton:
    Noooo Ken those are horrible and they are ugly. They do work though.
    #8 3 years ago
    Squeeze taps look like ass...just solder and shrink looks 10x better
    #9 3 years ago
    Quoted from markp99:
    Yes, you can add the third wire for your "y" connection. It will not compromise the crimp.
    When I was doing aircraft wire harness work, we were allowed to add one "filler" wire into the crimp to "take up slack". For example, assume you were going to splice two different gauge wires into a butt splice and on one side the wire was 16 gauge and on the other side the wire was 22 gauge. With a crimp size that allowed for 16 gauge wire, the 22 gauge wire would be too small to be crimped tightly. So, the solution was to add an extra piece of 22 gauge wire to take up slack and crimp both the 22 gauge wire along with the short piece into the butt splice. And then after you made the crimp you would cut off the extra wire from the short piece down to the butt splice. And then you would apply your shrink tubing and be left with a good tight crimp with 16 gauge wire on one end and two 22 gauge wires on the other.
    This practice was written into our wiring specifications and approve by the FAA. We crimped and added shrink tube. We did not solder our crimps with our aircraft wiring. It was not required. But we used the insulated water proof shrink tubes like these:
    amazon.com link »
    or these:
    amazon.com link »
    In your situation, you could also place a small piece of filler wire on the other side if needed. Say you are butt splicing 16 gauge wire on both sides all you have to do is add your wire to make the "Y" then you would also add a short piece of 16 gauge filer wire to the other side, then cut off the excess and follow with your shrink tube. This will give you that good tight crimp on both sides and you would not need to solder; However, because I am using cheap generic shrink tube like the stuff you buy from Autozone or Harbor Freight, I like soldered connections and I would solder and then follow with with the shrink tube.
    I would like to clarify that I don't solder crimp connections when I am re-pinning the connectors that fit in the circuit board because it is not needed. And a good butt splice doesn't need soldered, either, but soldering will give you a more solid connection.
    Sorry to get carried away and get so wordy. It is a fault of mine.
    #10 3 years ago
    Personally, I don't like using crimp or press on connections on anything that is going to vibrate or move around, unless it is a crimp and solder combo.
    If I were wanting a secure splice on a wire like that, assuming the wire has to be cut, I would :
    Strip long
    Twist up one end of original wire with new added wire
    Slide on piece of shrink tube onto doubled wire
    Slide another shorter piece of shrink tube (may need to be a size smaller diameter shrink) onto single wire
    Take twisted wires and combine with other original wire via a lineman splice kind of style for mechanical connection
    Solder all three together
    Slide single wire shrink up to soldered splice (only over single wire) and shrink.
    Slide double wire shrink over entire soldered splice and single wire shrink tube until flush at other end and shrink. (This way the single wire has that piece of shrink over it to make it fatter so outer piece of shrink that covers whole thing is more evenly shrunk down ... may be mostly cosmetic, but I feel it can help keep the soldered splice from tearing through the shrink sometimes).
    This creates a nice solid mechanically sound splice; it may be overkill, but I like doing things once.
    Notes:
    Depending on situations like if I am worried about shrink slipping around or moisture, I may use adhesive shrink. Or, I may use a second outer piece of shrink (so 3 total piece) if my shrink tube I am using seems cheap/thin (admittedly, this adds thickness and doesnt look quite cad nice).
    Notice I did not solder any wires first. All twisting of wires should be done first. If you solder first then twist, you are trying to twist a solid hard bundle that may lead to cracking and a potential damaged wire (now or noticed later)...stranded wire is stranded for a reason (well several reasons-depending on application as well).
    Side question - why do I see a red wire having a black wire spliced into it??? That's just asking for trouble to me...
    Like I said, this is just one method for a solid connection. I am sure there are many more, and most any mentioned already would probably do the job for this application.
    Edit : people, PLEASE use a heat gun or other hot air to shrink the tubing...why do I see so many people thinking lighters or flames of some type are how you use shrink tube???....
    #11 3 years ago
    Quoted from cottonm4:
    amazon.com link »
    or these:
    amazon.com link »
    You mentioned it not being required to solder after crimp for FAA. I believe it. I recall some military specs on equioment I've worked on in past where the specifically state soldering after crimping (a pin or connector) is not allowed. Their theory is that the rigidity of the hard soldered end is more likely to crack and break under heavy stress/vibration that the stranded wires when properly crimped (with the recommended zillion dollar crimpers of course. Lol).
    On my home stuff, I typically don't solder crimped pins etc, but do like to solder on things like crimped ring/fork terminals when I can...I like knowing it isnt going to come off. Even though a good solid proper crimp really shouldnt anyway as we know.
    Extra note - it was also required to be lead solder when we did solder work.
    Does FAA require lead solder still? Just curious, don't want to side track thread too far
    #12 3 years ago
    I'll take a look at the crimped butt splice option and try a few samples.
    Quoted from pacmanretro:
    The example was just for illustration. Its actually a BLUE wire The colors match appropriately in the 4-wire bundle I assembled last night.
    #13 3 years ago
    I'm sorry. I partially misspoke. On some of the jobs, while we did not solder directly with a roll of solder, the shrink tube we used was insulated shrink tube with a ring of solder on the inside. Once the crimp was made, we used a heat gun with a special "U" shaped end that would apply heat evenly around the shrink tube and melt the solder to the wiring.
    These shrink tubes have that ring of solder inside. It is a metered amount and fully encased within the tubing. With heat, the tube shrinks, the adhesive on both ends melts for waterproof protection and the solder melts, fully contained with no solder drips anywhere.
    And we used the AMP crimpers that cost about $300.00 each.
    amazon.com link »
    The wiring that did not get soldered was when a connector pin was crimped on and installed in a cannon plug. With a cannon plug install the connector was shoved/inserted inside a chuck of silicone rubber for 100% moisture proofing.
    Man, I love cannon plugs. If they were not so expensive, I would rather use them instead of Molex connectors.
    Same here. I like to use unprotected ring terminals so I can solder them but they are hard to find. My local hardware store has, unfortunately, quit carrying them.
    #14 3 years ago
    Lol, I've soldered insulated ones and when plastic melted/split off wound up adding a piece of shrink (adhesive if I have it large enough on hand) over it.
    I don't think I've ever used anything with solder already inside it. Very interesting!
    #15 3 years ago
    These are the types of threads that remind me how Pinside can be great!
    #16 3 years ago
    Quoted from xeneize:
    Lol. If it wasn't for the excuse it provides me to solder on a regular basis I probably would have given up pinball years ago!
    Few things are as instantly gratifying as desoldering, soldering components on a board and having it look 100% when finished.
    $ 9.99
    KAHR.US Circuits
    $ 19.00
    The MOD Couple
    $ 54.99
    Great American Pinball
    $ 5.00
    Allteksystems
    $ 64.00
    $ 48.00
    $ 6,995.00
    Classic Game Rooms
    $ 59.00
    Pixels Arcade Games
    $ 19.95
    $ 90.00
    Lighting - Under Cabinet
    $ 99.99
    Playfield - Plastics
    Ramp-O-Matic
    $ 36.99
    Pinball Stuff
    $ 159.99
    $ 7,599.00
    The Pinball Place
    $ 4.49
    $ 43.00
    The MOD Couple
    Metal-Mods
    $ 40.00
    B & K Mods
    $ 495.00
    MI Pinball Refinery
    The MOD Couple
    $ 50.00
    $ 40.00
    Arcade Arts
    $ 369.00
