Unfortunately, most of the DMD pins, regardless of the mfg, will require the HV version of my XP-DMD4096 DMD displays. A good rule of thumb is if the game has an original High Voltage plasma display, you will need my HV DMD display. Having said that, only the later Stern games that were released with LED displays would use my LV version.
Here is the reason:
I have yet to find any games from the era of the plasma DMDs that have a strong enough 5V system to support the needed 5-10Watts for an LED DMD. WPC is the worst culprit. It has been well documented over the years how the 5V power supply in the WPC games is at it's limits already and most of the original power driver boards have had multiple rebuilds on them. The designs of the other mfgs are about the same.
I opted, in order to be plug'n'play, that I would utilize the +65V supply and buck it down to +5V as efficiently as possible. Maintaining the high efficiency of the conversion, I can get the 5V power needed without taxing the 5V system.
Another rule of thumb is that Red, Orange, Amber, and Green require less power to operate than Blue and White in my DMD's. There is nothing I can do about this because it is all about chemistry and what it takes to get those colors.
XPin
