(Topic ID: 21283)
XPin™: Official Announcement (2 of 3)
By XPinPinball
11 years ago
  • 7 posts
  • 4 Pinsiders participating
    #1 11 years ago
    To all our Pinball friends out there:
    PHOENIX, Arizona (July 27th, 2012) — XPin™ is proud to formally announce that we have officially launched our new XPin™ X-BRIDGE line of products including the XP-WPCHV and XP-WPC95HV — The solution for the weak OEM +65V supply in WPC-S and WPC89 systems when installing an XPin™ XP-DMD4096 LED DMD display.
    The OEM +65V supply has been well documented over the years as being an area of the display system that is constantly being rebuilt. For this circuit, it is not a question of if it will fail, but when!
    Our new XPin™ X-BRIDGE XP-WPCHV and XP-WPC95HV have been designed to plug directly into the same headers used for the AC voltage coming into the D-14039 and WPC Audio/Visual boards and the associated output voltages that would be passed back to an OEM Plasma DMD. Since it is primarily designed for the XPin™ XP-DMD4096 series displays, it is only going to generate the +65V necessary to power the display.
    View our new XPin™ X-BRIDGE XP-WPCHV here:
    http://www.xpinpinball.com/products/xpin_power_supplies/XP-WPCHV
    XPin™ is currently in the manufacturing stage of these new products which currently show Out of Stock. We wanted to let everyone know that these products will be available soon, so please check back regularly.
    For more information, please refer to our web site at http://www.xpinpinball.com
    If any of our products are currently out of stock then please visit one of our Distributors for your XPin™ Products.
    Xpin™ truly is EVOLUTION–EVOLVED.
    XPin™ Pinball Products
    Brett Davis, CEO
    [email protected]
    #2 11 years ago
    It sucks to have to buy a $65 part to provide 65v to a 5v board. I would much rather have to twist wires. In fact, one of the benefits of these led dmds is that you can have a dead video board and they still work. I have a pinled installed for this reason. If nothing else, there should be a header where I can solder or connect 5v into the Dmd without buying an additional kit.
    #3 11 years ago
    I guess you won't be buying one of these kewl displays huh?
    #4 11 years ago
    I was planning on buying 10 of them to be honest.
    #5 11 years ago
    Markmon you can afford it you have thousands into powder coating and the like to bling your machines. No worries.
    #6 11 years ago
    Quoted from Squeakman:
    But it seems silly to spend $65 to avoid twisting some wires. Will there be a schematic?
    #7 11 years ago
    Markmon,
    There is a 5V version that I haven't listed yet. The issue is that you are in a minority when it comes to the typical pinball owner. Most individuals I know outside of the pinball community would not consider the "twisting of wires" method.
    I am not sure where you would tap off of 5v, but I can assure you that in the WPC games that the 5v supply coming out of the driver board cannot support the power requirements for any LED DMD's. PinLED DMD has the user splice into the 12Vac line and they regulate it down. A viable solution except that the 12Vac transformer wiring may not be able to support the additional 1A load presented by the DMD.
    When you see my announcement for the 5V version, drop me a line and I can discuss a strategy to hook it up if you want.
    Brett
    This page was printed from https://pinside.com/pinball/forum/topic/xpin%e2%84%a2-official-announcement-2-of-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
