XPin™ has a 2nd new product announcement: The XP-BLYFF
With the help of Sean Palmer, a new solution is available to remove the annoying flicker that occurs when LED lamps are installed in the feature lamps of your classic Bally and Stern games. Not to take away from the existing solutions out there, but this simple solution is a breeze to install as can be seen in this YouTube video, which is also posted on the XPin website.
For those of you not wanting to replace a working OEM lamp driver board, or solder together a similar kit, and are looking for a quick and easy way to eliminate the LED flicker, here is your solution!
Here is the product page link: http://www.xpinpinball.com/shop/product/xp-blyff
// Error: Image 421970 not found //// Error: Image 421969 not found //
