Quoted from jackal2001:That isn't new to 1.23. I saw the same bug in other code revisions also. Ball got stuck behind left NC and no ball search ever kicked in.
Jackal2001, did the mode lock up and the Nightcrawler never release the ball? I've had balls get stuck behind Nightcrawler, but the mode always ended, Nightcrawler went down and then the game went on. In his video...the Rogue time is stuck at 20. I've never had that before.
The business of left Nightcrawler popping up and staying up in Xavier mode when he is not the mutant, needs to be changed. He is blocking the Xavier shot which is needed to get the clue to where the mutant is. I do like the Nightcrawlers sometimes being used in Xavier mode and sometimes they are not. I also like them occasionally being used and him NOT being the mutant, but which Nightcrawler is up should always switch in any mode (Xavier, Rogue and Nightcrawler). I also believe that if Nightcrawler is used in Xavier mode and he IS the mutant....it shouldn't matter which one you hit (left or right...whichever one is up at the time). I also think that if he is used and NOT the mutant.....he should stop (both stay down) during the mode as soon as either Nightcrawler is hit. He is one character and both Nightcrawler switches should be considered one hit to Nightcrawler. They could have wired both switches together and saved $.03 worth of wire on that as far as I'm concerned.
To address any stuck balls behind the Nightcrawlers....if they are popping up and down in each mode as I have suggested this wouldn't be an issue. If a switch hasn't been hit in awhile and the game is thinking it's ball search time....the first thing it needs to do is lower any raised Nightcrawers (or even switch which one is raised would work) before it goes into a full blown ball search. There is no reason to lose the locked balls without checking behind the raised Nightcrawlers first.
On a general Nightcrawler note....It would be nice to change the timing on their switching. Not from mode to mode, but anytime they are used. Have it cycle between a couple of quick switches to some longer "I'm gonna jiggle before I jump" type switches. I know they can do it so why not? I also don't understand why lefty seems to always be used first (in Rogue and Xavier mode anyway...I don't think I have seen Nightcrawler mode since 1.23 rolled into town).
