Xenon Start Up Problem
(Topic ID: 225467)
By JasonGood
28 days ago
  • 18 posts
  • 6 Pinsiders participating
  • Latest reply 12 days ago by zacaj
#1 28 days ago
My xenon has been in my family since 1981, but it’s been in sitting in a shed for 20. After turning it on for the first time in forever, the general illumination lights turn on, but nothing else. The kick up sound doesn’t start and the attract lights don’t start either. I’ve tested the bulbs and the sockets and the sockets work, but some bulbs didn’t. So I replaced most of the bulbs. Same thing happened. I also tested the sound board. All the sounds start playing, so it’s not the soundboard. I also tested all the fuses:all good. So I have no idea why attract mode isn’t starting. I can’t play unless it starts up. Please help, and I will be so happy.
#2 28 days ago
Your MPU probably isn't booting. There's an led near the bottom of it that should blink 7 times. If it blinks less than that, the number of blinks should narrow down the issue.
#3 28 days ago
zacaj oh yeah I totally forgot. I also checked the MPU A5 solenoid board and the led flashed 7x
#4 28 days ago
Quoted from JasonGood:
Check TP3, should be at least 20VDC
#5 28 days ago
Did it have batteries in it? Also did you check the 2 big capacitors under the plastic piece? They probably need replaced as well as the pin connectors checked for cracked solder.
#6 28 days ago
zacaj zablon Here’s an image of what I’m dealing with. I tested the blue capacitors on the top right corner board and they were good. There aren’t any batteries from the looks of it. What board are the pin connectors on?
#7 28 days ago
That white cylinder on the bottom of the MPU is a battery. Looks like it's already got some corrosion. I'd clip it off before it corrodes any more
#8 28 days ago
zacaj oh my gosh, I never would have seen that, thank you so much, this must be the problem. If not I’ll post again
#9 28 days ago
If you're getting all the flashes the battery isn't the problem, but it will be soon if not removed
#10 28 days ago
Yea, that board probably needs a lot of work.
1. Clip the battery (it won't affect gameplay)
2. remove that board from the back box and take a toothbrush and some baking soda and scrub that area (any that looks corroded) to neutralize it. Then clean it with isopropyl alcohol.
3. Replace the 2 big blue capacitors - most likely those are your issue
4. While the board is out check the back of the boards - the connectors I was referring to are where the cables plug in. You need to inspect each pin solder joint - most likely you should try to reflow the solder on them, but not knowing your skills I would start with the first 3 steps and see if that gets it running.
I do think that some battery damage has been done on the left side...but you'd need to look closely and see if any traces were damaged (eaten through) on both the front and back.
#11 28 days ago
zablon alright I’ll definitely try that, and thank you so much
#12 27 days ago
Yea, classic battery corrosion problem. Also make sure all the balls are in the game. If you get 7 flashes on the mpu and no boot it's usually because the ball switches are not registering.
Zabs list is spot on with a 'barn find' like this.
You can find Cap kits on ebay for these games. Assuming the battery damage is not fatal caps and solder reflows should get you going.
#13 27 days ago
Is there a ball in it? Andnd does the ball trough switch work? Xenon won't boot unless it detects a ball in the trough.
#14 27 days ago
Quoted from erak:
Won't it need two?
#15 27 days ago
Read the repair guide section "Before turning the game on" Lots of info on things to be checked, upgraded and repaired when aquiring a used game.
http://techniek.flipperwinkel.nl/ballyss/rep/index1.htm#mid
#16 27 days ago
erak oh jeez, I didn’t even think of that
#17 12 days ago
zablon zacaj ok, nevermind, I looked at the led on the MPU board again and when you turn on the machine, it’s a quick blink and then a flash, a pause, and then 5 more flashes. The manual states that the led should do a flash, pause and then 6 more flashes. What should I do?
#18 12 days ago
Sounds like your MPU isn't detecting the 43V for the solenoids. Possibly just a bad fuse on the rectifier board. If they all check out then check the voltage at TP3 on the MPU
Third Coast Pinball
Yorktown Parts and Equip
Displays
PinballSolutions.eu
1,500 (OBO)
Canal Winchester, OH
$ 7.65
Cabinet Parts
Third Coast Pinball
$ 7.65
Cabinet Parts
Third Coast Pinball
