I have a strange issue with the sound on this xenon. Certain switches hit and the spinner cause it to just repeat the same sound over and over until something else is hit. I will upload a video. Can anyone help?
WTF! Well the speech and sound appear good. I would look for a signaling issue first with the MPU and sound board connections. Always a good idea to resolder the connector pins and inspect and repin the wires if necessary.
Quoted from BigAl56:WTF! Well the speech and sound appear good. I would look for a signaling issue first with the MPU and sound board connections. Always a good idea to resolder the connector pins and inspect and repin the wires if necessary.
My same reaction haha. I've been waiting to see if anyone had any experience with something like this to dig back into it but I will take your advise and give that a try.
In diagnostics, go into switch test and see if you have any stuck switches. Perhaps the spinner switch is sticking on occasion. If that doesn't bring anything to light, isolate the spinner switch contacts with a piece of paper and then see if you can reproduce the problem.
Quoted from minnesota13:In diagnostics, go into switch test and see if you have any stuck switches. Perhaps the spinner switch is sticking on occasion. If that doesn't bring anything to light, isolate the spinner switch contacts with a piece of paper and then see if you can reproduce the problem.
I did try that. It does the same thing when I hit either stand up target as well as either of the 30 point rebound switches
This page was printed from https://pinside.com/pinball/forum/topic/xenon-sound-issue-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
