So I got a Xenon recently and there is no sound from the game at all. I took out the Sound Board and attached Vocalizer to examine and tested the TP's. All the TP's on the Sound Board are reading as they should, except TP1 which is about 3v high (reads around 16 - supposed to be closer to 13) and TP4 is reading about 2v where it is supposed to be 0. There are no hacks on the board.
The vocalizer is not getting any reading at TP2 which is supposed to be 5v. CR 1-3 diodes have been replaced but are all reading ok.
I took out all the ic chips and sanded any gunk off, replaced all the caps on both boards, replaced the two pots... nothing is working still.
Any help is appreciated!
