Xenon solenoid probs fixed last week thanks to Quench, now it's on to the next thing.
So here's the particulars:
Right pop bumper fires in solenoid test, but not in play. Its switch doesn't register in switch test. Brown/white "row" wire does not have continuity to A4J2-14 connector.
Right inlane switch also doesn't register in play or during switch test. Same brown/white "row" wire as above, and no continuity again to A4J2-14.
Now here's where I'm baffled: schematics have the same brown/white wire leading to the #2 drop target. I test its continuity to A4J2-14, and I get the beep, so that switch is fine. I check continuity from that drop target switch to the right pop bumper switch, and I get a beep. I check from the pop switch to the right inlane switch, and I get a beep. They're all connected, so how am I not getting continuity from the pop & inlane switch to the board??
All other switches test fine in play and in switch test, and all other solenoids fire both in play and in solenoid test. A4J2 connector has been re-crimped. Right pop bumper has a new capacitor and a new diode (a 1n4004, since I don't have any 1n4148's, but I don't think that's a problem, right?)
One other thing which may or may not be related: when I check the pop bumper switches in switch test, none of the four of them register, BUT the solenoids fire. Same thing with the two slingshots, nothing comes up in switch test but the solenoids fire. I don't know if this is normal Bally behavior so I don't know if this should happen or not.
