Hello!
Need some guidance into the latest issue on my Xenon. The "middle" pop-bumper energizes the second I power on the game. Doesn't blow any fuses. If I disconnect J5 (center pop is J5 pin 15) from the driver board it does not charge. If I disconnect the coil the switch works properly in game.
A little background to this issue:
I accidently wired this pop the wrong way - power wire to the non- banded diode I turned on the game and started smelling the very unique smell of what I found later discovered to be the coil. It blew the F4 fuse on the rectifier board which I found was too high (15amp). Then it blew up the resistor/transistor on the solenoid board.
I traced the Transistor feeding the coil (Q10) and replaced it with a TIP102 along with the 330k ohm resistor and 1N4004 diode in it's circuit (pic incase I missed something important to replace?)
I replaced the Bally coil, AN-26-1200, with a spare Williams A2-26-1300, assuming they would be compatible?? I put a 1N4004 diode facing the same way as the rest of the bumpers and put the yellow power wire to the banded side. I also replaced the switch diode and clipped the cap to make sure it wasn't shorting and like I previously mentioned, the switch works in-game when I have the coil disconnected.
Any ideas what else to check?
TYVM!
