(Topic ID: 136044)
Xenon MPU Board ROM Jumper Question.
By Arcade
  • 29 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by Arcade
#1 4 years ago
Just picked up a Xenon with a bad MPU board.
I got a replacement board that tests good and works.
However, I am not sure about all the jumper issues with the ROM chips.
In the photo below my broken board is on the right and new replacement board is on the left.
I have already taken my two ROM chips out and moved them over to the new board on left.
However when I put it in my Xenon I get no green light at all on the board.
Do I need to adjust some jumpers or am I missing something else all together?
I can take closer or better photos as well if that will help determine what is wrong.
#2 4 years ago
It depends on the style chips.
My suggestion...order new game ROMs from John Wart.
He uses 2732 chips.
The jumper settings can be found here:
http://www.twobits.com/ballympujumpers.html
#3 4 years ago
If the new board didn't have the right jumper settings for the chips you installed, you more than likely fried those chips.
Order some new ones from John.
thatpinballplace.com
#4 4 years ago
Here's a better link to the proper jumper settings:
http://www.actionpinball.com/tech/35_rom_mod.php
#5 4 years ago
jumper settings for 2732 chips:
2732 EPROMs in U2 and U6:
The following is a comprehensive list of settings for all 36 jumpers on the board, when using 2732 EPROM chips in locations U2 and U6: ("nc" = not connected)
1 nc, 2 nc, 3 nc, 4-13A, 5 nc, 6 nc, 7-8, 8-7, 9 nc 10-11, 11-10, 12-GND, 13 nc, 13A-4, 14 nc, 15 nc, 16 nc, 16A-29, 17 nc, 18 nc, 19 nc, 20 nc, 21 nc, 22 nc, 23 nc, 24 nc, 24A nc, 25 nc, 26 nc, 27 nc, 28 nc, 29-16A, 30 nc, 31-32, 32-31, 33-35, 34 nc, 35-33, 36 nc
#6 4 years ago
Yes, I can see that the new board is not jumpered the same so once you get that done, should be good to go!
#7 4 years ago
He'll still need to order new game ROMs
#8 4 years ago
You have 2716's at U1 & U2 and a 9316a in U6.
#9 4 years ago
OP...keep in mind, with the game ROMs ordered from John, you DON'T want to make your new board jumper setting to match your old board. You'll want to make the jumper settings match what I posted above.
#10 4 years ago
Don't worry, you didn't fry your chips. I can look at my Xenon, which I believe is an all-original board, and let you know what the jumpers should be.
#11 4 years ago
So far, in the early Bally games I own, I only have game ROMs in U2 and U6
I'm not sure about the ROM you have in U1...I'm not familiar w/ Xenon. I had a board that I swapped w/ another...it too, had a chip in the U1. John told me to remove it and leave it out of the game. This was for a Lost World, which doesn't use the U1 chip. Once again though, Xenon might use that chip. I don't know.
John will set you straight though....he really knows his stuff.
#12 4 years ago
From what I've been told, the original CPU board, and it's jumper settings have nothing to do with the jumper settings the OP needs to be using. The jumper settings are all driven by the chip style used in the game ROMs.
#13 4 years ago
Thanks. Great info. I will get with john
#14 4 years ago
Xenon had more code and required the additional chip at U1.
#15 4 years ago
Now that you mention it...I think the board I swapped into my Lost World was out of a Xenon. If that's the case, the game ROM set will consist of the U1, U2 and U6
#16 4 years ago
I'm still getting used to working on these old Ballys. I'm more familiar w/ system 11 and WPC games.
#17 4 years ago
He does not need new ROM's if he jumpers the board right or if not are not comfortable doing the jumpering the order those for how the new board is configured.
#18 4 years ago
I'm not exactly sure what you're saying there Pbpins.
#19 4 years ago
He's saying if he doesn't want to bother with soldering new jumpers, get new ROMs to match the way the board is currently configured.
#20 4 years ago
I put my U1 and U2 chips back in the original boards so I can ask John the easiest way to make it work without having to re jumper the board.
Does he have a Pinside Account or is it easier to go through his web page. (I have not visited it yet, but will soon).
Just for fun here are both boards with everything back in place.
I had only moved U1 and U2 over as I thought those were the only two Game Roms. (I am a System 35 noob).
#21 4 years ago
Looks like John sells 2732's
Here are a couple of close up photos in case someone can tell if this new board is jumpered for the ones I can add to cart from his site.
#22 4 years ago
No, you'll have to change your jumpers....for starters, E12 needs to jump to ground.
Give me a call...I sent you a PM
#23 4 years ago
If it were me I would just change the jumpers on the new board and use your existing chips. If you don't want to mess with jumpers I could change the jumpers for you and test it in my Xenon. I can burn chips too and have 2732s on hand if for some reason your ROMs are bad.
#24 4 years ago
Thanks to everyone who has replied in this thread.
I have sent an email to John @ Thatpinballplace.
I am starting there but will certainly keep everyones awesome offer in mind.
You guys are the best and are what make our hobby as great as it is.
I really appreciate all the great info that appeared here in such a short amount of time.
#25 4 years ago
Anyone know Johns Pinside name?
No response so far from his web page email.
#28 4 years ago
With new ROMs you still need to change the jumpers.
#29 4 years ago
Quoted from kursiv:
You are correct.
I finally have this all straightened out.
Got a quick education on Stern and Bally system 35's.
$ 40.00
B & K Mods
$ 8.00
Third Coast Pinball
$ 19.99
PinballElectronics.com
$ 40.00
B & K Mods
€ 3.95
Multigame
3,500 (Firm)
Sale Pending!
Hermosa Beach, CA
