My Xenon launches 2 balls into the shooter lane when I start a game.
What should I look for?
I’d check the switch at the bottom of the playfield that activates ball eject. Easy to mash contacts together when dropping playfield back into cabinet. This is what happened to me anyways…
Quoted from Yesh23:You have too many balls in the game
I only have 2 balls installed.
I'm not familiar with Bally games of this era but is there a ball trough runaway wire gate under the apron - could that be broken?
Quoted from LORDDREK:I’d check the switch at the bottom of the playfield that activates ball eject. Easy to mash contacts together when dropping playfield back into cabinet. This is what happened to me anyways…
This. The game doesn’t know it successfully ejected a ball, so it tries again.
Quoted from indypinhead:My Xenon launches 2 balls into the shooter lane when I start a game.
I've had this problem. Screwed with my head for a while. Seems it's a programming glitch...both balls need to be in the outhole after a memory "clear". So picture when it was new out of the box, 2 balls dropped on PF and then turn it on. Not in the trough.
So what has fixed mine more than once was remove the 5101 or cut off the battery charge briefly, reinsert 5101/restore the charge, then before turning on the game drop the 2 balls onto the PF and just let them fall into the outhole. For whatever reason, this "resets" the switch config of the outhole and trough when it loads them, then should work again like it should.
This page was printed from https://pinside.com/pinball/forum/topic/xenon-launches-2-balls-into-shooter-lane and we tried optimising it for printing. Some page elements may have been deliberately hidden.
