(Topic ID: 214880)
Xenon gray posts
By Moto_bone
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by WeirPinball
#1 3 years ago
I'm working on a xenon restoration currently and I'm missing a few parts. I'm trying to track down the exact sizes of the 5 gray colored posts that are holding the ramp up.
Can anyone who has a xenon pull a scale out and kindly provide me with the sizes please!
#2 3 years ago
there were 4 different sized posts I had (2x) 1-1/4" ; 1-3/16" ; 13/16" ; 1/2"
I showed a pic of how I reinstalled them
the switch cover were (2x) 2"
the plastic around the pop were (2x) 1-5/8"
hope this helps
#3 3 years ago
Thanks chas10e that definitely helps a ton!
I'm sure it will help others at some point as well!
#4 3 years ago
I tried to just "drop a scale" down on each one thinking they'd be only 2 sizes.
When I first got it & cleaned it up as good as I could I simply put things back as I took it out & a couple of the posts were incorrectly placed I guess. I also move the left tube strap close to the end of the tube
having redone it helped ME out, the ball doesn't hang at times going in the tube entrance anymore.
if you know where I can get the proper wire for the tube switch that would be great ( my original broked & I bendied-up an extra coin switch wire)
1 year later
#5 2 years ago
That helps with part of the question - last thing to figure out is what size spacers are under the metal cover behind the ramp.
#6 2 years ago
I didn't snap a pic of them but in my post above I think I measured 2 inches
the posts holding the plastic were 1 5/8"
Quoted from chas10e:
hope this helps
#7 2 years ago
perfect - guess I needed to read it twice. My measurements were a bit different, but made it work. Thanks much!
