(Topic ID: 57867)
Xenon Flipper Coil Overheats
By crashnt20
6 years ago
  • 12 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by girloveswaffles
#1 6 years ago
Hi, the coil on my left flipper over heats to the point that it actually melts the plastic sleeve inside the coil. I replaced the coil with a brand new one and it still melted. Could I have it wired backwards or something. Or is it something else. Thanks everyone.
#3 6 years ago
I installed a brand new EOS switch. It's a brand new flipper build kit. Is there a way to make sure that the wires are installed properly.
#4 6 years ago
Not just the wires have to be installed correctly, but you need to set the gap that the EOS opens when the flipper is fully extended - otherwise the coil will overheat.
#5 6 years ago
Sorry if I am dumbing it down too much, but when I first started repair I wished people would talk to me like I was a child (because I didn't understand what they were talking about). The flipper needs high power to perform a flip. To HOLD the flipper in the upright position requires much less power, so there is an end-of-stroke leaf switch that shuts down the high power. If this switch is not being activated or is not gapped quite enough then the high power stays on the whole time each and every flip and your coil gets super hot.
Again, sorry if I am stating the obvious here. But vid1900 is almost certainly on the right track. If the coil was wired backwards I'm pretty sure that would short components out on the board...
#6 6 years ago
Quoted from jitneystand1:
I like it dumbed down. I did not know that but now it makes sense why there is a different test for hold on my other machines
#7 6 years ago
As far as your other machines, this wouldn't apply. The flippers on xenon are tied to end of stroke in such a manner that when the flipper extends, the eos actually cuts the high power. On all your newer machines, a high power pulse is sent by the CPU and hold power is used eos or not.
#8 6 years ago
Here is a picture of what my switch looks like. Tell me what you think
#9 6 years ago
The switch is installed backwards. That arm on the pawl is supposed to open the switch when th plunger pulls down.
#10 6 years ago
ha ha ha ha ha ha ha ha really. That is awful!!! I'm an idiot. Thank you so much for your help. I will swap it around. Thanks.
-1
#11 6 years ago
Quoted from girloveswaffles:
Yep, it sure is!
#12 6 years ago
Quoted from crashnt20:
Well, at least you wired it up right.
Edit:
Just realized, that doesn't look like the right switch.
There should be three blades. two long blades (only one with a contact point) and the long one with a contact point should have a plastic stand-off between the two longest blades:
http://www.marcospecialties.com/pinball-parts/ASW-A20-34
$ 149.00
Displays
PinballSolutions.eu
$ 90.00
$ 14.50
PinballElectronics.com
4,100 (Firm)
Sebring, FL
