I can not seem to find the problem with my Xenon. Any help would be greatly appreciated to solve this head-scratcher.
Basically when you have a captured ball in the lower saucer and the second ball goes into play, the first time you hit any of the four thumper bumpers with ball 2, it will eject the captured ball when it should hold it till you collect 3 more top saucers. If I manually go through the 3 saucer shots it will proceed normally and put second ball into play, but hit any thumper bumper and the captured ball flies out.
I am running an Alltek MPU with an original solenoid driver board. I've been checking switches, diodes, and any possible bad wiring, switch test shows 0 codes, and I just can't figure this out.
