Xenon club...Members Only~Try Xeeeenon
(Topic ID: 174124)
By Yesh23
2 years ago
  • 283 posts
  • 62 Pinsiders participating
  • Latest reply 19 days ago by JeffZee
  • Topic is favorited by 27 Pinsiders
There have been 77 images uploaded to this topic. (View topic image gallery).
There are 283 posts in this topic. You are on page 6 of 6.
#251 74 days ago
Quoted from bobukcat:
Maybe he doesn't have a new one laying around??
Maybe, but you can't clean an old one. The carbon and metal flakes are embedded into the nylon.
Buy a bag of them (50 for $15), cause almost every coil uses that same sleeve
Wipe the plunger off with alcohol so you don't contaminate the new sleeve
#252 74 days ago
I don't know about everyone else, but you get completely screwed on shipping unless you have a big order all at once. That .50 piece turns into $10 because it's the only thing you need.
#253 74 days ago
Quoted from Zablon:
Definitely a challenge for anything ordered versus being able to buy locally but some vendors are definitely worse than others. It is one of the reasons I use Pinball Resource so much.
#254 74 days ago
If he needs one I have plenty.
#255 74 days ago
Quoted from Zablon:
Just 5 minutes of labor to go pick your part, put it in an envelope and print a label would cost more than .50 cents.
#256 74 days ago
I miss mine too, it was mylared but way back then there wasn't an internet so I didn't trust trying to remove it without possibly screwing things up.
#257 74 days ago
Quoted from Breger1:
I have a Xenon that I recently restored, came out great, just having a few issues that I hope someone can shed some light on. After plugging everything back in I learned I had a few wires on incorrectly, which was fixed and machine started up after. the first issue now, the outhole ejector fires very faintly and will not advance the ball up the guides to start a game. If I push the ball up manually it will start up and can play. Secondly, I had great flippers before restoration and now the left flipper is rather weak and also sticks at times for a few seconds. Change EOS?
thanks for the suggestions
What was the problem causing the weak flipper?
#258 73 days ago
So an update, I took the coil mech apart for ball trough. I simply cleaned the plunger and the coil sleeve (yes I don't feel like ordering one and paying shipping cost, at least at this time. I recently ordered $250 worth of items from Pinball Life and Marco...when I build a significant list up again to justify shipping cost it will be on the list). I also replaced coil stop. It works perfectly now. If the problem returns I will modify to raise the ball guide up higher to decrease angle.
#259 73 days ago
Quoted from MJW:
I still haven't completely nailed this one down yet. I replaced EOS, have yet to rebuild. My inexperience led me to purchase just a nylon bushing, coil stop, and sleeve. Wish I would've done a rebuild kit. I also replaced the cabinet flipper switches, which significantly helped, as the are a lot tighter now. Down the road I will do the flipper modification to Fliptronic
#260 73 days ago
Here are few pics of the restoration. Overlay turned out pretty good. A fun machine and classic, will be a keeper.
IMG_2973 (resized).jpgIMG_3215 (resized).jpgIMG_3217 (resized).jpgIMG_3227 (002) (resized).jpgIMG_3254 (002) (resized).jpg
#261 73 days ago
Wow, your PF damage was worse then mine! I'm thing of replacing the playfield, on the list for the next run, fingers crossed.
#262 73 days ago
Quoted from Craigb:
Worth every penny.
#263 73 days ago
Hi all. I have an issue with my right hand side targets where they get stuck up high. I tightened checked and clean the mech underneath but any advice appreciated.
#264 72 days ago
Quoted from BJM-Maxx:
That sure looks like an original Bally capacitor on that switch. I would start there.
Replacing that cap seems to have done the trick!
#265 71 days ago
Quoted from Jakusu:
Does, the flipper move freely with game off, not rubbing on playfield, coil sleeve, not binding?
#266 71 days ago
Quoted from Jakusu:
Did they used to work for you?
Did this happen after a playfield swap or new rubbers?
#267 71 days ago
They were working ok.
The long bracket on the target bank came loose and I retightened. Only one now getting stuck. I will try and get some pics.
Thanks for the replies so far.
#268 71 days ago
On a plus got to fit my custom coin inserts as well!
#270 65 days ago
Well I was able to verify that the game will play...so the tear down begins. Definitely needs some attention.
I'll keep you posted. I will have a couple of project playfields for sale if anyone is interested
20181016_162603 (resized).jpg20181016_162614 (resized).jpg20181016_162620 (resized).jpg20181117_154214 (resized).jpg20181117_154224 (resized).jpg20181117_154237 (resized).jpg20181117_154252 (resized).jpg
#271 65 days ago
timab2000 do you have the backglass?
#272 64 days ago
Quoted from Zablon:
Yes I do it's not in the best shape would like to find a nicer one
#273 63 days ago
Anybody have any playfield and backglass scans to share? Thanks!
#274 54 days ago
Made some progress on my game in the past couple of days. Cleaned the bottom of cabinet, repaired the bad and busted area in the back cabinet fiberboard or whatever they call it.
Cleaned up the coin box plate and replace some of the wood for that, and cleaned up the transformer/rectifier plate. Looks better than it did. I'll post more as I get to it.
Tim
20181117_154224 (resized).jpg20181128_151147 (resized).jpg20181128_151227 (resized).jpg20181117_154214 (resized).jpg20181128_151441 (resized).jpg20181126_135410 (resized).jpg20181128_151018 (resized).jpg
#275 46 days ago
Decided to start a new post on the makeover of my Xenon, rather than clog this one up. If you are interested here is the link:
https://pinside.com/pinball/forum/topic/xenon-gets-a-makeover-on-a-budget-hopefully
Thanks Tim
#276 26 days ago
Does anyone know where I might find a reproduction power supply warning decal you know, the yellow sticker that goes on the power supply board believe it has red lettering. Thanks in advance
#277 26 days ago
Quoted from stashyboy:
a Pinsider that restored a Bally Eight Ball Deluxe had the decal reproduced.
Check the Bally Eight Ball Deluxe club.
#278 20 days ago
Quoted from Kevlar:
Silly question time, what do the pop bumpers score on xenon? The manual and the instructions in pinball arcade say 100 per hit, mine however are behaving very strangely, giving anything from 100 to 1600. Maybe a faulty diode somewhere?
Following on from my initial post, here's a vid of the scoring from pop bumper hits. I haven't been able to spend any time on it yet as its at a friends house not local to me. In the video you can see me activate the 4 pop bumpers, the first one scores 800 every time, 2nd and 3rd score 100 each correctly, and the 4th scores anything from 100 to over 1000. I'm pretty sure no other switches are being activated by vibration. I notice each switch has a diode and a capacitor on so I'm thinking ( hoping! ) they are causing the problem and it'll be as easy as replacing those. Anyone seen anything like this before?
#279 20 days ago
Quoted from Kevlar:
The 4th pop bumper is scoring 800 points in the video like the first pop bumper.
A clue is that the two yellow standup targets on the left side each score 700 points so that's probably where the extra score is coming from. You'll need to work out if it's a vibration issue or switch matrix issue. First off, put a piece of paper between the contacts on both of those yellow target switch contacts to stop them activating and see what happens to the pop bumper scores.
The pop bumpers and those yellow targets all have capacitors on them, make sure none of the caps has broken a lead.
#280 20 days ago
Quoted from Quench:
Thanks for the reply. In the video, yes, 800 for both but its just a short video, its not always 800. Good suggestion, I've just asked my friend to test your theory. Thanks.
#281 20 days ago
Quoted from Kevlar:
Don't forget to go into switch test mode and check each switch one by one. You'll need to remove both balls and reset the drop targets up before you start the test so that there's no closed switches. Activate each switch starting from the highest number working your way to the lowest number as they're identified in the Xenon manual. It's important that you do it in reverse order and note any incorrect readings.
#282 20 days ago
Quoted from Quench:
Thanks very much for the info, my friend has confirmed one of the yellow standups was very sensitive and has adjusted it. Strange we didn't find this before as he had previously tried the thump the playfield method and not found the dodgy switch.
#283 19 days ago
Any of you Xenon troubleshooters want to take a crack at this one? Enter Xenon...
https://pinside.com/pinball/forum/topic/xenon-interminent-coil-pulsing
$ 7.65
Cabinet Parts
Third Coast Pinball
Third Coast Pinball
Third Coast Pinball
$ 149.00
