Quoted from PantherCityPins:Two questions:
I built and installed Wolffpacc tech LED scoring displays. Fantastic product BTW! Anyhow I’m getting a loud hum after plugging in the displays. It wasn’t there prior to plugging them in. Grounding issue??
Second, some of the vocalizations are a little garbled, like the “Try” in “Try Xenon”. It sounds almost like the speaker is overloaded but the sound doesn’t change with volume. The speakers are new. The main sound board has been recapped, I haven’t done anything to the vocalizer board though. Thoughts?
Stupid question, did you connect the ground strap from cab to head? Transformer grounded properly? The transformer grounds between the metal mounting plate and the cab ground braid. The humming can be difficult to trace. I had this with an EBD, grounding the lamp driver board helped. Does the sound change when the scores switch from current to HSTD scores in attract mode?
Adding the LED score displays can rob too much of the 5V supply. You need to make sure all connectors involved have a solid connection.
Garbled speech, did you swap out the sound and speech pots with the re-cap? Turn the speech pot from low to high a few times and see if it improves. Clean with tuner spray if you have some. Try re-seating the 40 pin interconnect ribbon. Swap out speech pot if no improvement. Newer design has an enclosed case to keep dirt out. GPE has them. If that doesn't work, re-cap Vocalizer.
