Quoted from Kderrick:This switch is one finicky mofo. Any tips or tricks appreciated. I’ve been adjusting it for weeks. I replaced it with a new wire. Before, weak tube shots push back ok but fast ones would blast past the switch and wouldn’t activate. Now slow shots get trapped after the switch. I’ve been adjusting it and leveling the machine. Frustrating. Thanks all.
Okay so, that's not how that switch needs set up. It is indeed a pain to get right making your own but once you get it set up, you don't need to mess with it again.
Don't use hard piano wire, use the same wire that is on the coin mechs (It is indeed the same exact switch and wire as the coin mech). It also is bent awkwardly coming off the switch in around a 45 degree down, then a 45 degree horizontal (or as close as you can get it) to make the wire level with the hole. If you don't line it up correctly it will rub on the metal. Additionally, the wire needs to come out past the hole, sticking into the lane some, and go back out so you have just a hoop sticking out (like an inlane switch). Round it in a half moon so that a ball rolling backwards just rolls right by it. This prevents the hang ups you are seeing.
It looks like from your pic you are missing the lock washer/nut that keeps the wire in place. If you don't use the coin mechs, you could just swap out the coin mech switch with the ramp switch and then bend the wire how it is needed.
