I'm trying to resurrect a 1983 Bally X's & O's that sat for a while before I got it and would appreciate any advice on what to look for next as I'm getting stuck with my limited knowledge. Original mpu had minor corrision and all I got on power up was GI lights and displays occasionally showing garbled numbers. What I've done so far is replace the line cord (original had ground prong removed) and added a new MPU and Driver board from nvram.weebly. Also replaced one female connector because the original wouldn't fit on the new mpu.
1E494EEA-B6B3-43C0-89EB-AAC62EB5FF62 (resized).jpeg08C35A7A-2F82-4FD3-8AC7-AECBBA61243B (resized).jpeg740FAF04-A078-43F4-8299-3375F651B760 (resized).jpeg
Since adding the new mpu the displays came back fine and the game will boot into attract mode and I can go through the tests. All coils fire and I don't see any stuck switches in test. If I press the start button the knocker fires once and it will subtract a credit and seems to go into a game but I don't get game sounds and the ball is never ejected to the shooter lane. If I remove the ball from the trough by hand it causes the game to reset so that's as far as I'm able to get. Also I've had the game reset when just activating the flippers so it seems more than one thing is causing it to reset. In addition I've found that when in a game, activating either the slam tilt switch or tilt bob causes a pop bumper to fire. Side note, on power up the lower pop bumper pulls in once like it's being activated, not sure what is causing that.
I've found a few cut capacitors on stand up targets I'll start replacing next but not sure if that will help much with these issues. Any advice is appreciated, thanks!
