Was doing some LED swaps and noticed the backboard is transparent. Not solid wood like we are used to. There are 6 flashers on the back side of the backboard.
Also noticed that the spotlight that shines on Magneto is a 161 lamp and not a standard LED. When I put a standard LED in, it didn't even work.
Speakers from FF will need to be updated with a new wiring connection. It doesn't connect via z-clip anymore. He is working on it.
Installed a mantis (tron) scoop hole protector but it needed some modification. I sent Kerry the info with pics and hopefully he will have something out shortly.
There is a mylar strip in front of the scoop (like Tron) that is really invisible. You can't find it unless you run your fingernail over the edge of it.
