(Topic ID: 16030)
X-Men - Official Club Thread All Welcome!
By pmWolf
8 years ago
  • 11,944 posts
  • 591 Pinsiders participating
  • Latest reply 5 hours ago by Puffdanny
  • Topic is favorited by 98 Pinsiders
There have been 1,039 images uploaded to this topic. (View topic image gallery).
5 key posts have been marked in this topic (Show topic index)
There are 11944 posts in this topic. You are on page 232 of 239.
#11551 1 year ago
I recommend this bust. Zip tie it w/blue zips. You’ll never notice them. It’ll still “move” a little to cushion air balls.
amazon.com link »
#11552 1 year ago
Quoted from Guinnesstime:
amazon.com link »
That one is pretty cool and I hadn't seen it before. Do you have any pictures of how to route/orient the zip ties?
#11553 1 year ago
Quoted from desertT1:
Don’t have the game anymore but tried adding pics (on mobile) in hope they’re in here.
There is a post behind wolverine that was easy to wrap around. I just put some double sided Velcro on bottom of him for extra support. Easy reversal to old wovie.
12FBC2E6-DA60-4EBF-8FAA-0C8DFF7BD1FD (resized).jpeg16BECA97-48DD-4420-A233-EA5150D87443 (resized).jpeg4273A9E5-296D-4EC8-9DA9-A7584388A619 (resized).jpeg4F323470-1807-4B4E-8BAD-D6674F191779 (resized).jpeg
#11554 1 year ago
I used a rubber keychain. Will never break, looks clean and doesn't dominate the playfield. I cut a lexan piece to go underneath it to replace that incredibly crappy one that comes with the newton ball kit.
#11555 1 year ago
Some pretty good ideas. If I cleared the paperweight one I get it would have the same shine as the factory Magneto.
#11556 1 year ago
FYI...that is the exact one that I have seen armless. Twice.
Great looking though!
#11557 1 year ago
Quoted from Jediturtle:
I never had air balls on my LE. Wasn’t an issue.
#11558 1 year ago
I get enough airballs to be concerned. Nightcrawlers and Magneto standup targets (lock targets) are a big culprit.
#11559 1 year ago
Quoted from FatPanda:
Same here. The airballs are not overboard like some games, but they are there (just like every other game). Plenty of guys use nicer statues and they look great. Not trying to stop anyone from doing what they want...just reminding them that there is a decent risk they may get broken. Some people will get lucky, some not so much.
#11560 1 year ago
Setup and playing great . Thanks buckman ! I’ll have to work on some of those high scores now
E70528C9-72CE-49A2-9630-0351B86CB564 (resized).jpegEA9462CA-F1CC-442F-B1BE-3E390A0F2EE8 (resized).jpeg
#11561 1 year ago
Quoted from Boat:
Looks very nice!
#11562 1 year ago
The callouts are so cheesy I’m not sure if I should keep them in for entertainment or replace with pandas upgrade
#11563 1 year ago
Quoted from dmieczko:
Quick question regarding the Magneto ball lock - sometimes when "LOCK" is flashing Magneto will not lock a ball with an up-the-middle shot on the first or second attempt. It grabs the ball perfectly, holds for a second, but then releases it. If the "LOCK" is hit from one of the side shots, it always holds. I have tested all the switches in Magneto and the trough, and they all function perfectly. Is there something I should be looking for, or is this just a part of the code that doesn't allow a quick shot to be locked straight up the middle?? Thanks.
I had this exact problem. Switches were testing ok. I noticed the 1 Way ball gate behind magneto was stuck up.
Set it back down and it’s working 100%
If I had to guess there’s some internal timer that counts down to reduce the chance of balls getting stuck there when they aren’t supposed to.
#11564 1 year ago
Left scoop question. Years ago I had an X-Men Magneto and as far as I can remember, every time the ball came out of the pop bumpers to the left of the villain scoop, it would drop into the villain scoop just about every time.
I purchased a different X-Men Magneto and now when the ball exits the pop bumpers to the left of the villain scoop it does not fall into the villain scoop most of the time.
Both games had/have a Cliffy protector.
The main difference is I added red super bands to the current game which may be a bit thinner than then original rubbers.
What is the "correct" behavior when the ball exits the pop bumpers to the left of the villain scoop?
Michael
-1
#11565 1 year ago
Correct behavior is sometimes the ball should go in the scoop when leaving the bumpers and sometimes it won't.
If it always goes into the scoop from the bumpers thats not as intended.
Quoted from mbelofsky:
Michael
#11566 1 year ago
Quoted from luvthatapex2:
Thanks. So my current game is about 70/30 not going in/going in. So this seems correct.
#11567 1 year ago
I find a well timed bump to the side of the cabinet will increase the chances of the ball going into the scoop.
#11568 1 year ago
It's about 50/50 for me, Mantis Protector. If I really need it to go in, I'll nudge the machine to better my chances.
I found with the Cliffy, it would almost never go in.
With that said, anyone want to buy a Cliffy?
#11569 1 year ago
Have a cliff ball goes in naturally maybe 10% of the time.feels right that the ball shouldn't go in there unless I want it to with a nudge or a shot.. Without the cliff it went in 70 to 80% of the time which slowed down the game and didn't feel right.
#11570 1 year ago
As sad as it makes me it's time to leave the club Anyone looking to join take a look at my ad here - https://pinside.com/pinball/forum/topic/for-sale-x-men-le-37#post-5006443
#11571 1 year ago
mantis scoop protector best buy imo
1 month later
#11572 1 year ago
Just got an xmen le. The Nightcrawler for some reason stays up doesnt go down. Anybody encounter this?
#11573 1 year ago
I just fixed this problem on my le. One of my wires broke off on the coil for the pop up release. For me it was a simple task of resoldering one wire. I suppose u could need a new coil as well.
#11574 1 year ago
I manually put down both nightcrawlers. In the coil test they both dont work. Although they do register a hit when I manually press them. The game for some reason doesn't recognise the coils
#11575 1 year ago
Do your magnets work? They are connected to the same driver.
#11576 1 year ago
cnuts13 I just had the same nightcrawler problem. Check the 2 fuses under the playfield (not in the backbox) to see if they've blown. If they have you can try replacing them, but if they blow again straight away, it's probably an issue with blown transistors on the aux driver board (search this forum for it). I had to order a replacement board (part number 520-5325-00) and all was good once it was replaced.
I was advised by the distributor to check the nightcrawler coils, magnets and relays powered by the aux board for shorts before installation - but everything was good, so not sure what cause the aux board to blow (but it certainly had - when we tested the old board 2 of the transistors had gone).
#11577 1 year ago
There was a problem with the first run of boards for the night crawler it should of been replaced long ago but mine was nib until around last November and wasn't swapped out yet.it went out around February and Stern sent me the updated board free.check to see if you have the rev 2 board.
#11578 1 year ago
Thanks for the feedback guys. I noticed that both magnets also don't work. I only found 5 fuses under the playfield and they all seem intact. Does anyone know the specific location for the fuse that operates magnets and nightcrawlers?
#11579 1 year ago
You need to fix or replace the aux driver board.
https://ksarcade.net/stern-aux-drv-520-5325-00.html
#11580 1 year ago
I think if the magnets are also not working its definitely the aux board (it basically controls nightcrawlers, magnets and a few relays) - surprised the under-playfield fuses are intact (although they might just seem ok - I've seen some fuses blown that seem fine visually). It's a pain as it means you'll have to order another board and wait for it.
Note that the link in the post above is for a Rev. A board, which exhibited a lot of problems. Stern eventually produced a Rev. B board which is less likely to have issues in future - its not bulletproof though because my board that went was actually a Rev. B.
Anyway - what I'm trying to say is it's maybe best to contact your local Stern distributor and order a Rev. B board replacement.
#11581 1 year ago
Quoted from HighNoon:
Ask and you shall receive...Xavier mode shots. I put this together last year with help from others on this thread.
--Luke
thanks, that stupid mode always seemed like luck. Didn't know they were all designated to certain shots.
…. damn now I have to memorize all these little heads
#11582 1 year ago
Quoted from hocuslocus:
Did you know if you just hit Xavier again, the needed shot will light? Of course if you are like me, that shot shrinks by a good 40% once the mode starts, LOL!
#11583 1 year ago
Another way to reveal the Xavier shot is to start a Villian mode prior to starting it if you have stacking enabled.
I usually start Shadow King then Xavier mode because they use the same shots
#11584 1 year ago
Really?! ok, yeah that's a lot easier then memorizing those tiny heads.
Quoted from bballfan:
I was going threw some of the older parts of this thread and saw stuff about stacking, I just assumed it was part of the old code. Mine is on whatever the default settings are. Pretty sure I haven't been able to stack hero's. or do you mean villians with heros?
#11585 1 year ago
Hi folks. Joined the LE club. This is a good game, really glad I got it.
But the game makes an insanely loud “clacking” noise whenever the blue/white GI go off. I think it’s the relays under the playfield making this noise. But why? During the game, whenever I hit a “light lock” target (the ones by Magneto”, I get the clacking. I’ve never experienced this on any machine. And it’s not the minor sound some games make (LOTR for example) when the lights strobe or whatever, this is LOUD and unusual.
Any hints or advice?
Thanks.
#11586 1 year ago
Quoted from TheFamilyArcade:
Thanks.
I think the noise you are hearing is the spinning disk.
You will need to add an e-clip onto the shaft underneath the playfield.
Scroll thru this link for details:
https://pinside.com/pinball/forum/topic/how-to-fix-xmen-le-spinning-disc-rattle?hl=nighttrain
#11587 1 year ago
I’ll check that. I have my doubts though. We’ll see. Thank you for the input!
#11588 1 year ago
After reading that thread and watching the YouTube video, that looks - er, sounds- exactly right. So looks easily fixable.
I appears I have the alt sound for game, which is mostly terrific, but the Storm callouts are still kinda ridiculous. That’s the cartoon Storm?
#11589 1 year ago
both of my night crawlers are stuck up.... assuming it's a fuse, but I've read this was a problem.
did anyone try to up the rating by maybe 1/2 amp?
#11590 1 year ago
Yes, that is the Storm from the 90s TV series. She sounds ridiculous but that is how she is portrayed in the cartoons, and what the voice actress tried to do in the Stern version but just couldn't quite nail it.
#11591 1 year ago
Anyone know a permanent fix for magneto lock releasing balls intermittently sdtm?
#11592 1 year ago
Quoted from PinDescabarian:
Is the game level? Warped? That lock is offset, so dropping a ball out of it should not go down the middle. If the game is level, maybe the two rods that trap the ball are not aligned all the way and it is tipping the ball towards the drain somehow.
#11593 1 year ago
Every now and then the ball will drop sdtm. Normally when two balls are locked. You think someone would make something that redirects the ball to it flipper all the time.
#11594 1 year ago
This never happens to my game. I did have to fiddle with the leveling. Mine is very slightly off to the left and this has worked perfectly for the past 4 years.
3 weeks later
#11595 1 year ago
Added the newton ball mod and a custom wolverine I clearcoated. Looks pretty slick!!
2B3DC6C6-FB42-4B3A-9F2A-EDC4C6165759 (resized).jpeg1F0CF49C-EAD7-4FD9-9D41-4EDFE0FEB634 (resized).jpeg7B6B89DB-51B6-4ECD-A46E-5461539A47B2 (resized).jpeg
#11596 1 year ago
Looks good! Hopefully airballs don't get him!
#11597 1 year ago
Quoted from Jimmyhonda:
Added the newton ball mod and a custom wolverine I clearcoated. Looks pretty slick!![quoted image][quoted image][quoted image]
Looks freaking cool, but if you value it, I would think twice about putting it in without some sort of protective shield. A friend of mine has that same statue and knocked an arm off almost instantly. Looks great though!
#11598 1 year ago
I have the same statue it’s been there for about two years never had a problem, looks great!
#11599 1 year ago
2 questions I need some help on ...
What are the sling sizes on X-Men? I put in 2 1/2" and I think the manual might have another measure?
What are suggested replacements for the LEDs that originally came in this game?
I'm seeing many that are failed or failing (dimming)
I replaced a few with Comet 2 SMD for now
#11600 1 year ago
Still have it too.....I think.
4,400
Pittsburgh, PA
Arcade Upkeep
