X-Men - Official Club Thread All Welcome!
(Topic ID: 16030)
By pmWolf
6 years ago
  • 11,462 posts
  • 552 Pinsiders participating
  • Latest reply 1 day ago by FatPanda
  • Topic is favorited by 95 Pinsiders
There have been 915 images uploaded to this topic. (View topic image gallery).
There are 11462 posts in this topic. You are on page 223 of 230.
#11101 11 months ago
Quoted from Jeep2682:
Thanks for the updates DugFreez and TimeBandit on lamp#63; that is crazy that they went to the effort to put in the wiring and a separate circuit, which is used only in attract mode. I wish it would light when the Wolverine is running that way we could have it turn on a spotlight or something.
You can wire up a spotlight that is tied to the Wolverine flasher on the Playfield with that effect. I did it on my game.
#11102 11 months ago
Quoted from Lermods:
Sure, that would be a great idea. I have attached a photo of my new wolverine and also a photo from under the playfield so you can help ID where to connect the flasher to. Thank you for the help
#11103 11 months ago
Quoted from DugFreez:
Playing 1.51? or the often un-updated 1.5? As everything I have ever read about the latest code (1.51) says the villains DO NOT reset and there is no 2nd loop or do again on them after they are completed.
This was a major reason of why many people didn't update from 1.5 to 1.51. I think fixing the ball lock timing fix in 1.51 made it worth the update alone.
Mine has been on 1.51 since I got it, I can guarantee that you can replay the villains again once dark phoenix ends.
#11104 11 months ago
You're gonna burn your retinas out without a frosted dome on that scoop bulb.
#11105 11 months ago
Connect it to the flasher socket. Either solder wires on to the lugs or use alligator clips. Orange is the power, black is the signal/ground.
#11106 11 months ago
Quoted from ryandimx:
For the people who replaced Wolverine with the Newton mod and a mini bust, do you have any issues with the Quake putty and lifting the playfield? Or has everything stuck okay?
I used the museum putty stuff and the bust would fall over after a couple weeks. I used a small l bracket behind him and hot glued it. No issues since.
#11107 11 months ago
Quoted from KenM:
Do you have a picture? I have him in my hands right now about to go on.
#11108 11 months ago
Going to assume it's about the same as mine.
The bust is porcelain so I just drilled a small hole in his back and put a small screw in it. Solid as a rock with the Velcro on the bottom as well.
#11109 11 months ago
Thanks for the idea on the flasher I will give it a try.
I am building a Blackbird that lights up that will take the place of the red LED above the scoop.
I have attached a photo of how I attached wolverine.
Drill the bottom of wolverine with one hole,
Insert a soft lead plug like you would put in concrete,
I used JB Weld but it was overkill,
Let dry overnight,
Mount wolverine to blue plastic,
Screw blue plastic down on mod,
Works great and easy to take off if needed.
Wolverine came from ebay (used).
#11110 11 months ago
Quoted from 85vett:
Thanks. Got the smallest bracket they had. Screw popped out once it was in so I ended up using some epoxy on the screw. Bracket + quake putty so hopefully he's not going anywhere.
2 mods to go and then I'm finally done.
#11111 11 months ago
Let dry overnight,
Yikes.. Be careful for that wolvie magnet core before it starts damaging your playfield. You might want to get that out and replaced before it turn into a nightmare.
#11112 11 months ago
Hey guys joining the club friday. Can someone point me in the direction of a good wolverine replacement and must have mods. Ive heard theres some pinbrowser work that enhances the game. Game already has color dmd, shaker and i got pinstadiums. Any other suggestions on good additions
#11113 11 months ago
There’s a lot of mod potential with this game. Best mod is the mezel newton ball replacement. Undercab lighting works well on this game, very active. Search eBay for Wolverine figures. Shaker, side mirrors. Get rid of the stock magneto. Speaker lights.
Here’s a few mods we sell for ideas.
https://lermods.com/t/x-men-pinball-mods
#11114 11 months ago
Got a link for that magneto? And wolverine?
#11115 11 months ago
Quoted from Robertstone0407:
Magneto
ebay.com link
Wolverine I used, I cut him at the waist.
ebay.com link
I'm sure you can find them cheaper.
-1
#11116 11 months ago
...or a person can get their Speaker Light Kits (along with acrylic designs and various accessories for the light kits) from the person that originally thought up the idea and has been selling them for the past 5+ years at www.speakerlightkits.com
Lermods, why can't you think of a mod idea of your own instead of copying mine?
#11117 11 months ago
Anyone have the interactive ramp kit installed? Is it worth it?
#11118 11 months ago
What would cause the lower right flipper to stay up until something else fires and the flipper will drop. I've replaced the bushings, coil sleeves and plungers. Flippers have enough play not to bind. The switches look good. Any ideas?
#11119 11 months ago
#11120 11 months ago
Quoted from trk12fire:
Return spring good?
#11121 11 months ago
Yes looks fine. I guess it wouldn't hurt to replace it. I took everything apart and cleaned it. Looked like a little shred of plastic was hanging in the coil sleeve. This might have caused the problem. It seems to work fine now. However, this is the 2nd time I've taken it apart and it seems like a temporary fix.
#11122 11 months ago
I was going to say bad coil sleeve .. but you said you replaced it.
Double check the plunger that it’s nice and smooth as well.
You can always cut a couple of rows off the spring as well, to give it a bit more grunt.
rd
#11123 11 months ago
left the club today / will miss it / already do/ never got to danger room, it was way to short a stay but downsizing must occur ./ May even sell my STLE
#11124 11 months ago
That coil stop is mushroomed and should be replaced. Probably not the cause though but it can happen.
When you say bushing. Did you replace both the white one that goes through the pf and the metal one in the linkage (in the white part of the plunger). Most miss the second one which can cause stack and binding.
#11125 11 months ago
Quoted from 85vett:
I wasn't sure how good that coil stop was either, that's why I took a pic. I'm not sure which bushing your referring to. I replaced the plastic going through the playfield.
#11126 11 months ago
Quoted from rotordave:
rd
I like the idea of cutting the spring down.
The plungers, elbows, sleeves, buttons and bushing were replaced.
#11127 11 months ago
Increasing spring pressure feels like a bandaid for the issue unless that spring is bad.
The metal bushing that goes in the white hinge on the plunger.
www.pinballlife.com/index.php?p=product&id=277
If this bushing is bad it will create play in the linkage. Double check that there is about a credit card thickness between the flipper bat and the white bushing going through the PF.
#11128 11 months ago
Quoted from 85vett:
http://www.pinballlife.com/index.php?p=product&id=277
I forgot about that bushing. I'm not even sure I put one in, when I installed new plungers. Now I'm wondering how many of my games don't have it. Now, there's a new open can of worms. haha. Thx Vet
#11129 11 months ago
#11130 11 months ago
Does the flipper bat have a little play? Meaning are you able to give it a little wiggle up and down in the rest position with your hand. If the flipper bat is tight against the plastic gushing it could cause the issue. Also if there is too much play, the the same thing could happen. Just a thought.
#11131 11 months ago
Yes, there is just the right amount of wiggle. Thanks Tom
#11132 11 months ago
this my x-men LE with pinduino interactive apron and ramps
#11133 11 months ago
Quoted from kimzone:
Kimbo - always bringing the bling!
rd
#11134 11 months ago
OK, I've gotta ask this and potentially take the punishment.
I've had my X-men for a couple months now and I'm a bit confused about some feedback I keep seeing about this game. I keep seeing people post about the depth of the rules and that is why they enjoy the game. I haven't seen this depth so I'm starting to wonder if I'm missing something major. Here is what I know:
- Each hero is started by hitting their shot 2-3 times (except Wolverine which I think is 5). When in their mode you are basically shooting their shot again a couple times to complete them.
- Starting a hero advances your magneto JP value and the amount of damage you do to him per shot so it's ideal to start as many as possible before going into magneto.
- 10 combos starts deadpool whom will help complete modes
- you can stack a hero in with a villain but not the other way around
- Wolverine MB has two options for each shot. The correct path advances you faster.
- Villain modes require _ number of shots to complete. They are throughout the PF
- Some how you light a gambit hurry-up shot worth a crap ton of points by shooting the left orbit and the top right pop bumper in sequence.
- Completing 4 modes (I believe) starts nightcrawlers
- Their are 2 wizard modes. One for completing villans and another for completing heros
- You have 4 MB's (not including wizard modes) with Wolverine, Magneto, Hellfire and Brotherhood
The game is still fun as I like the shots but the rules so far feel pretty shallow to me (nothings wrong with that) but since I keep seeing these comments about how deep the code is I figured I'd ask. After watching Bowen's tutorial it didn't help me understand anything I was missing.
#11135 11 months ago
I think the game is difficult. I frequently get near danger room, but never dark phoenix. There is alot to do in the game and it keeps me coming back. I've been to danger room twice in 4 years. There are 8 heroes and 8 villains, so plenty of fun characters to meet and battle. Here are a few more nuances in the rules sheet.
https://docs.google.com/document/d/1RXQg7NEYahyzLrrT-E3WXAmhKNtT-eVfqc5GEWZdHL0/edit#
#11136 11 months ago
Quoted from 85vett:
Depends what the definition of “deep” is.
If it’s “confusing” like the JJP games, then X-Men isn’t that.
You have the handle on the rules. There’s plenty to do without having to keep a notebook at the side of the game.
I would guess a “shallow” game would be like the Segas and early Sterns where you hit each character 4 times to start a mode and each character started = mini wiz.
X-Men sits in my “happy place”. Complicated enough that you need to learn the rules to play it properly ... but not so complicated that you forget half the shit the next day.
rd
#11137 11 months ago
So far as call outs i got the game at +15 on speech and -10 on .music. really tames the callouts down
#11138 11 months ago
Anyone got any rule adjustments or changes they've made to enhance the game? I have it at factory currently. Also any enhancements to posts or rubber removals. I see alot of people remove the plastic posts by the ramp entrances and add these
https://www.pinballlife.com/index.php?p=product&id=323
#11139 11 months ago
Those are a must. I also consider target splints for the two lock targets. Those shots are already tight enough without having those dang targets leaning out into the lanes.
A lot do the wolvie bracket mod. I like it as it I actually have to try to hit wolverine now.
#11140 11 months ago
So i changed stacking villians and heroes and stacking heroes. I think it makes the game better but thats me. Ordered new blue titan rubbers and added pinstadiums. Connected them to the storm flasher on the back board and to the red GI light
Red gi light still allows max lighting without interfering with shadow king and other mode lighting
#11141 10 months ago
I made this, reduced air bails, just made the mistake to put rubbers on that where to thik, with thinner ones works perfect for me
#11142 10 months ago
Quoted from Gandalf37j:
What'd you make?
#11143 10 months ago
New wolverine installed, titan rubbers came yesterday as well
#11144 10 months ago
I'm not a fan of the newton ball mod but your new wolverine looks amazing! Most people that do this mod put a cheesy, silly looking wolverine in the originals place but the one you chose looks better then the original in my opinion. Great job!
#11145 10 months ago
Quoted from QuarterGrabber:
Its a paperweight. I think others used it too. You can get it on ebay
#11146 10 months ago
Now to finish the mod off,painted slider
#11147 10 months ago
hello guys I was thinking about selling my game of thrones limited edition and buy a pro xmen, what do you think? regards
#11148 10 months ago
Quoted from mannymasy:
Going to be a personal preference and especially lopsided in an X-men thread. I will be the voice of what I feel will be the minority here. I own both and if one had to go it would be my X-men. I love the shots of X-men but the strategy and rules in GOT (IMHO) are much better. The rules of X-men are good, it's just going to be what type of rules you prefer.
#11149 10 months ago
Of curse...
#11150 10 months ago
I have a few sets of icicles for the Iceman ramp if anyone is interested. $15 for the LE, $7 for the pro, both prices include shipping.
Professor Pinball
Professor Pinball
$ 12.00
Pin Mods
5,800 (OBO)
Salt Lake City, UT
Tucson, AZ
$ 200.00
Professor Pinball
Lighting - Backbox
