I got 10,000 post
Quoted from Kiwipinhead:I got 10,000 post
Show off!
I've made 112 posts / 10,000. Most of them crapping on about how xmen is cool.
rd
Quoted from rotordave:F me, us Kiwis are a helpful bunch.
This reminds me--which day is the Pinside wide Thank-a-Kiwi-Day?
Well, I ran through and confirmed that there is no magnetization going on with the balls. I use the pinball life ohhh shiny's, which are supposed to be good with this issue--but still, I gave it a check to confirm 100%. In the switch test, balls 1-4 each reads when being put back in the trough. The trough jam also shows as in service, but I'm not sure if that one is a good or a bad thing. Any more ideas? I feel like if I can get this fixed in the next day or two I'll be putting some serious damage on the sentinels.
Quoted from judremy:Check the screws on the back. Soon enough that part will break away and Wolverine will move for you.
Pinball Life has Wolverine figurine for $99 is that a good price?
COLORDMD X-MEN PREVIEW!
Displays are shipping now. Color ROM release is targeted for Friday, September 4.
Quoted from Dmod:COLORDMD X-MEN PREVIEW!
Any chance of seeing the smoothed images?
Quoted from DParcade:This reminds me--which day is the Pinside wide Thank-a-Kiwi-Day?
Is it still looking for the balls?
With coin door open and a ball on the trough up kicker and in switch test. Push up the plunger up and see if trough jam switch activates.
Quoted from rai:Pinball Life has Wolverine figurine for $99 is that a good price?
Cheaper than marcos and I doubt these will be around forever as they are a special mode and limited from what I have heard. I wonder if Stern still has any.
Quoted from Kiwipinhead:Is it still looking for the balls?
Okay, I have to come out and admit my frequent idiocy in the hopes that it helps some other fool in the future. I was playing with the optos in test and noticed that actually there were two optos showing active. Turns out, last night when I was tired and soldering the coil nice and tight I actually hooked up the molex connectors to each opto backwards. Fortunately, it doesn't appear to have done any damage...just gave me a firm lesson in taking pictures before I take anything apart!
Now I'm left to enjoy the X-men and contemplate this Color DMD addon...
Quoted from DParcade:Okay, I have to come out and admit my frequent idiocy in the hopes that it helps some other fool in the future. I was playing with the optos in test and noticed that actually there were two optos showing active. Turns out, last night when I was tired and soldering the coil nice and tight I actually hooked up the molex connectors to each opto backwards. Fortunately, it doesn't appear to have done any damage...just gave me a firm lesson in taking pictures before I take anything apart!
Live & learn, glad its up & running, now go enjoy
Quoted from judremy:Cheaper than marcos and I doubt these will be around forever as they are a special mode and limited from what I have heard. I wonder if Stern still has any.
Thanks, I bought one. Mine looks fine but in case they stop making them.
This new color dmd is the mod to get right now. It really brings the game alive. Now im just waiting for the topper by http://www.tilttopper.com/ and it will be good to go.XMLE in Color.JPG
Hopefully this hasn't been discussed to death already I haven't found anything on it in the forum so far. I was wondering if anyone has been having issues with the Rogue shot on their pro machines. Unless I massage the shot just right the ball either flies out of the ramp and back into the orbits or doesn't register the shot. Any idea's/solutions would be much appreciated, Thanks
Quoted from Thrillhouse:Hopefully this hasn't been discussed to death already I haven't found anything on it in the forum so far. I was wondering if anyone has been having issues with the Rogue shot on their pro machines. Unless I massage the shot just right the ball either flies out of the ramp and back into the orbits or doesn't register the shot. Any idea's/solutions would be much appreciated, Thanks
You don't mean Storm, do you? If you really mean Rogue (the shot that feeds into Magneto), then I solved it floating over the switch by installing a plastic cover over the area. You can make your own, or buy the ones for WH2O. I forget the site that has them. Which one do you mean?
Quoted from judremy:You don't mean Storm, do you? If you really mean Rogue (the shot that feeds into Magneto), then I solved it floating over the switch by installing a plastic cover over the area. You can make your own, or buy the ones for WH2O. I forget the site that has them. Which one do you mean?
Thanks for the idea. I do mean the Rogue shot, I shouldn't of said ramp. I'll pick up a bit of plexyglass and see what I cant come up with. If anyone does have a link to where I might find a cover online that would be a great help too, thanks again
Quoted from Thrillhouse:Thanks for the idea. I do mean the Rogue shot, I shouldn't of said ramp. I'll pick up a bit of plexyglass and see what I cant come up with. If anyone does have a link to where I might find a cover online that would be a great help too, thanks again
Some plexi should work. You just mount it under the existing plastics where there are screw points. It is the sharp turn area that you want it for. It will keep the ball in the loop and keep it low so it makes contact with the rogue switch.
I had a similar problem with mine and found that the Nightcrawler lid near the upper right flipper was raised a hair causing air balls and some bounce through the Rogue shot causing it to not register some shots. Adjusting the height of Nightcrawler stopped the air balls and started registering Rogue hits reliably.
Where did people purchase the icicles for the iceman ramps from? Been looking for some for my game and can't seem to find them.
Hi guys wondering if any one can tell me if theres an advantage to collecting an xmen more than once?, example if you have already collected beast solidly on your xmen team and start his mode again what advantages does it have?? thanks in advance..
Quoted from whisper:Hi guys wondering if any one can tell me if theres an advantage to collecting an xmen more than once?, example if you have already collected beast solidly on your xmen team and start his mode again what advantages does it have?? thanks in advance..
Points.....but replaying the modes get in the way of doing other modes that are not completed (unless hero stacking is turned on). Probably wise to time them out if your goal is to get farther in the game. Why risk losing the ball trying to complete a mode that's already been beat?
Having no option to turn off replaying beat modes is one of my bigger complaints about the code.
yeah true, that would be great if the modes didn't repeat after there beaten, Cyclops is always one I start more than once after its completed.
Quoted from whisper:yeah true, that would be great if the modes didn't repeat after there beaten, Cyclops is always one I start more than once after its completed.
Yep. Trying to start or retry Storm or Rogue.....going through Cyclops is the easiest way. It's really a bummer if you have him beat and then start him again when trying to get Storm going.
Yes, I've said this a lot. It would be simple for Stern code team to disable repeating modes or make an option in the menu to disable it or make a setting of the number of shots required before it repeats.
Quoted from DugFreez:Yep. Trying to start or retry Storm or Rogue.....going through Cyclops is the easiest way. It's really a bummer if you have him beat and then start him again when trying to get Storm going.
Good point, but I'm wondering why you don't turn on hero stacking.
The heroes that are completed take longer to start in subsequent trips.
So having Cyclops completed should not interfere greatly with starting Storm. It takes 5 shots (IIRC) to restart Cyclops, but only 2 shots to start the first Storm. Now, if the player is having trouble hitting the Storm shot, it might seem like Cyclops starts too often
Quoted from MrSanRamon:What settings are people using for the ColorDMD...DOTXL or Scan or...?
Robert
I did scan, it's like watching a cartoon in a way
Robert
Had all mine on different settings to work out which I liked best. All set to DOTDL now.
Quoted from lyonsden:Good point, but I'm wondering why you don't turn on hero stacking.
Because then the game is a cluttered mess.
Quoted from DugFreez:Because then the game is a cluttered mess.
I'm not trolling, just curious as to what you mean. I have mine set on stacking and really enjoy it. I like getting several heroes started, start a villain, then start a multball to clean house (well, as much as I can). Also, I like the strategy behind getting to Danger Room -- get heroes all started/completed, then Magneto MB, then play Danger Room. Dark Phoenix is still a dream for my skills.
With stacking off, the game just seems to drag for me.
Quoted from lyonsden:I'm not trolling, just curious as to what you mean. I have mine set on stacking and really enjoy it. I like getting several heroes started, start a villain, then start a multball to clean house (well, as much as I can). Also, I like the strategy behind getting to Danger Room -- get heroes all started/completed, then Magneto MB, then play Danger Room. Dark Phoenix is still a dream for my skills.
I just mean with stacking on it's impossible to make heads or tails of what you are supposed to be shooting for (unless you already know). I know what I need to be shooting for, but I can't get past what a mess it is with hero modes stacked.
Quoted from DugFreez:I just mean with stacking on it's impossible to make heads or tails of what you are supposed to be shooting for (unless you already know). I know what I need to be shooting for, but I can't get past what a mess it is with hero modes stacked.
100% agree with you here Dug! Stacking is horrible! It means you'll get further in the game but I like a challenge. I think I got magneto super jackpot for the second time ever last night and i've owned the game since new! Ive never reached danger room or dark Phoenix either but hopefully one day I'll get there!
Quoted from Sparky:I joined the Pro club this weekend. Boy, this is a long thead!
Yeah, it's nice to see a thread over 10k that isn't about pinheads getting ripped off.
I like stacking on and I like stacking off.
At first I didn't like stacking on at all, especially when the early code had the call outs all messed up, it did seem a real jumbled mess. Now that I'm familiar with what I have started, I don't think stacking is so bad. But it does let me get closer to DR more often.
Stacking off is more pure game, but you have the issue with re-starting completed heroes such as Cyclops that would block out others you are trying to hit. So I think this is a bit more complex.
But I love that we have the ability to paly both ways if we like one better than the other. Props to Stern for having this in the option menu, it really makes the game for me.
Can someone please post a side on photo of the blackbird scoop, and better yet measure the spacer height? I need to identify the spacers on the plastic that sits above the scoop & holds
the blackbird lamp. The previous owner took them off and as a result the led goes flying out of the socket every time I make the scoop.
Did anyone hear of a code update during the GOT Live Twitch w/ the guy that looked like jack sparrow? Does anyone have a link or time of who, when and where it was stated. Last time I checked (5mnths) ago, Waison stated, "Code is done." Thanks for any input.
Quoted from PaulCoff:Did anyone hear of a code update during the GOT Live Twitch w/ the guy that looked like jack sparrow? Does anyone have a link or time of who, when and where it was stated. Last time I checked (5mnths) ago, Waison stated, "Code is done." Thanks for any input.
He was talking about Avengers getting an update someday. XMEN is done.
I believe when it was asked Jody said he did not know of any X-men update and would have to check, and that was about it.
Pinsider: Chuckwurt heard differently regarding xmen code, but I'm always hoping for the best.
Quoted from chuckwurt:Not a joke at all. Also not crazy enough to watch again to get the exact time. Definitely mentioned it though. I've watched the feed twice. Heard it both times.
I also got the impression from that stream that there still remained a possibility to revisit the XM code, but nothing was planned. At Stern it's up to the individual developers to take the initiative, but no one outside of Lyman has any track record of polishing off code on their own, so if Waison doesn't feel like working on it, or it doesn't have a direct impact on the bottom line, it won't get another look.
Quoted from Baiter:Waison doesn't feel like working on it
Unfortunately, I believe this is true... besides ColorDMD is done with it (or would they be willing to go over XMEN again if there was an update and have they ever done an revision to color once a code for any particular pinball machine was updated?). I want to check out Magneto Multi ball in color and see if you can spot Cyclops within the balls.
Quoted from PaulCoff:Unfortunately, I believe this is true... besides ColorDMD is done with it (or would they be willing to go over XMEN again if there was an update and have they ever done an revision to color once a code for any particular pinball machine was updated?). I want to check out Magneto Multi ball in color and see if you can spot Cyclops within the balls.
You can
This page was printed from https://pinside.com/pinball/forum/topic/x-men/page/201 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
