Yes it does. That is what rotodave has. Make sure to check out his thread:
https://pinside.com/pinball/forum/topic/judremys-xmen-wolverine-solution-with-gameplay#post-2151723
I should have the new prototype installed this weekend. After I test it for a bit, I will give the go ahead to TMezel if all is well. There will still be other parts you will need to order if you want to use it. TMezel will only provide the piece to mount in the slot where Wolverine was.
These are the posts you need (4 posts with 3 rubber or Cliffy sleeves):
http://www.marcospecialties.com/pinball-parts/02-4036-1
You don't put a rubber sleeve on the back right post (on the Pro). On the LE, it might end up being the back left post. You can tell based on if a ball can hit the post.
The Newton ball is this one:
http://www.marcospecialties.com/pinball-parts/04-10005
You will also need a 3/4" ball. You can get these from packages of ball bearings on Amazon or elsewhere like this one:
http://www.amazon.com/Avler-Chrome-Bearing-Paracord-Monkey/dp/B00C7KGVK4/ref=sr_1_1
Unfortunately, I don't really have time to make kits and send them out. I did this for my own personal machine and others have really come to like it. I think the machine plays faster and better with this there. After all, it seems to have been in the original designs and only removed to add a very badly designed "toy". If X-Men had the captive ball like it was originally designed to, I think it would have sold better (and better software too).
rotodave, if you can update your first post in your thread with the part info, that would be great.
