Quoted from DugFreez:I believe:
http://shop.cointaker.com/category.sc;jsessionid=6E6BE8B7F1E571F4C7E183D8FA3D1006.m1plqscsfapp02?categoryId=136
As for the flashers...I replaced all of mine with LEDs, but stuck with cool white except for the left ramp (blue), under the disc (blue and red) and the right ramp (warm white).
My main suggestion to you would be to talk you out a yellow flasher for the right ramp. Yellow flashers (yellow LEDs in general) are, for the most part, useless. Well I shouldn't say that...they are good if they are in a location that you want yellow that is being seen by the naked eye or a place where you aren't counting on them showing through something yellow to make the light. Basically they are no good under yellow inserts or yellow domes. A regular incandescent flasher will look brighter and have more "pop" under a yellow dome than a yellow LED flasher will. The yellow just isn't powerful enough and when put under an insert or dome they look less bright. The correct call for the flasher under the yellow dome (right ramp) is a warm white.
That link definitely appears to be the right leds.
I know what you mean about yellow LEDs ~ they are dim.
I forgot about that. I'll change that color for sure.
THANKS!
