Quoted from mummite:Got Wolvie #248 yesterday. Really liking the game a couple things so far.
- Starting with Magneto multi-ball all the time sucks I want choices at the start. At least make this an option in the settings.
Agreed.
- Why does the magneto spotlight only come on when the coin doors is closed? what is that bulb wired to? and why is it that the only normal bulb in the game? I changed the bulb to an LED and it melted! seriously it melted the bulb. It was a normal LED cointaker super bright white. I put the normal bulb back in, any one had issues with this?
It is a 161 bulb. It is considered a flasher and that is why it gets no power when the door is open and no high power going to the playfield. You can replace it with a 161 LED (which looks very nice) or even a 906 LED flasher if you want to go super bright.
- The blue bulb on the right side above the sling always falls out. I need to adjust it, the rubber bangs right into it.
It sounds like your socket must be crooked. I would look under the playfield and see if you can get it mounted differently. Mine is a good 1/2 inch from the rubber.
- Is the blue light above the scoop suppose to flash when villain is ready? Mine does not and bulb is 100% fine
No...the villian insert lights, but the light above the scoop doesn't alwsy when villian is ready.
- Wolvie triggers perfect and no issues with my ramp hitting his claws.
Congrats on that. I had to wrestle with mine for 3 days to gat it adjusted propperly.
- Spinning disc seems fine, but I have to play it more.
I think my disc / magnet was making the clacking noise from the get-go, but a slightly bent e-clip fixed it.
- Also when selecting a Villian I feel like I press right/left once and it keeps moving to the next selection with no input? Also how do you make your selection? it should be start maybe?
Right flipper scrolls right, left flipper scrolls left. If you stop on Brotherhood or Hellfire and it isn't qualified yet...it will auto scroll off of it after a bit. Both flippers at onece chooses the selected mode on screen.
That is it for now. CAX weekend party @ my house tonight so we will see how she holds up
Mat
