Mine also had a problem with the Wolv claw hitting the ramp. The ramp would not move to second position because it was bullseyeing his claw, bending into it, giving up and moving back to original position, then trying it again, and again!
Had to take apart the jet behind Wolv, take Wolv completely apart, make new holes and re-mount him correctly. The way Stern should've. The reason it's annoying is because the Stern guys actually tried to fix it on mine.. the screw plate in Wolv was mounted twice (you can see from impressions) and he was crooked, leaning to the left, and it still wasn't even close to being able to let the ramp by. That was their attempt at a fix: mount Wolv leaning to the left and STILL have his claw impede the ramp so it can't move over. Nice one! This isn't something that rattled loose in shipping, or a switch unadjusted. It was nothing but pure laziness and shite QC from Stern.
As for everything else, seems to work fine so far.
Except the code is glorified pre-production demo code. Scoring doesn't work (Magneto scoring is whacked and doesn't give you credit for your shots, and then Wolv scoring gives you too much!) and once when I got Nightcrawler basically garbage came up on the screen... had a switch/coil test screen flashing, then garbage, then some NC animation, then random numbers, etc. LOL
On the plus side, the shots, lighting, sounds, dots and flow are all top notch! And easily Stern's most attractive game to date.
For what they're charging, though, their QC is just terrible. These are the LE games, and way overpriced; we owners should not have to take them apart when they arrive and finish the correct build of them simply because Stern's employees are too lazy or incompetent to do it themselves. Sending out non-working games with obvious problems (not talking about something that shook loose in shipping) is unacceptable to me. Looks to be common practice after reading this thread.
