-----MAGNETO MULTIBALL----
-The meat of MagsMB is pretty much the same; hero shots you make that haven't been started/completed are worth 50k, and hero shots you make that HAVE been started/completed are worth 300k, +50k per other hero started/collected.
-so if you start/complete every hero mode, then each shot is worth 1mill.
-progression to the SJP is still the same from 1.24/1.05
-after you collect the SJP, similar to 1.24/1.05, Mags, Iceman, Clops, Storm and Rogue will be lit for victory lap points of at least 600k per shot! Take as long as you want with the victory laps, you earned it! The victory laps will end when all but one ball drains.
-now, IF you have collected the SJP and have at LEAST STARTED (you don't have to beat them) BOTH DR and DP wizard modes, after your victory laps end, the scoop will start lighting up! I wonder what happens if you shoot it?!
-shoot the scoop after ending the victory laps and at least starting both other wizard modes, to Activate the yet-to-be-animated (just plain text on the screen) MULTIBALL WIZARD mode!
-the rules for this WMB seem identical currently to DP wizard mode: hit every shot twice and then hit the scoop a third time to collect the 30+mill SJP. The biggest difference between WMB and DP is that WMB is a MULTIBALL, while DP is a single ball. All scoring is e same, I believe.
-AFTER either beating OR draining down to one ball, the WMB will end, and ALL the Hero and Villain mode inserts will reset! So THAT'S how you get them to reset! :p. just simply get to BOTH Wizard modes, collect the MagsMB SJP and start WMB. Simple, yes?
My Opinion/intuition: I think that the Rules for this mode are temporary. I don't think that the final version of WMB will just be a mirror of DP, I think they just input DP mode rules in order to have some kind of scoring opportunity here. The mode is also NOT on a timer, so I don't think it's Deadpool either, at least not with those rules. So in short, it's just a placeholder.
I am of the suspicion now that Deadpool mode will be a 45 sec fast scoring wizard that will kill the flippers after 45 secs, a'la System Failure in Jurrasic Park, which I think would be awesome, I LOVE getting to System Failure on JP. Either that or some type of Sea of Simulation type if mode where you can collect and complete uncollected heroes. *shrugs* who knows.
