I figured I'd take some pics and post instructions on how to remove the upper playfield on WWFRR in case anyone needs it. The tools you'll need are:
-Phillips head screwdriver (large and small tip)
-5/32 Allen wrench
-9/64 Allen wrench
-11/32 small wrench
-Screwdriver with socket attachments (1/4, 5/16, 11/32)
First you'll need to remove the left and right wire ramps. Next remove all the plastic covers on the upper playfield.. You can leave the wires attached and just set them aside. Below you'll see most of the screws/bolts that need to be removed. Don't forget about the plastic cover at the very back of the playfield. Theres a clip that attaches is to the left ramp.
