Will this be all that is made? If so us 10 who get one are pretty lucky if you ask me.
Does anyone know the correct adjustment of the diverter on the back ramp? The one that diverts the ball down to the banzai or let the ball do a full outer lap...
Should it be possible for the ball to do the outer lap when the diverter is out and should direct the ball down to banzai (a hardish flip up on the left ramp)?
Cheers
/mima
Quoted from Nightmare:the left side is down and the right side is up
No Way.. I had right tilted written on my sheet, I guess I did it backwards according to the flyer. But I could swear I found a image and it was tilted right.
Honestly never looked at the flyer once.. wish I had, but I saw that pic and thought that was correct.. really sorry.
Personally Laseriffic, I don't care. I'm just happy you made one for all of us to enjoy. I just didn't know if it was made by design like that or the original poster mounted it wrong.
Looks great on there! Mine should be arriving by tomorrow! Thanks again to Laseriffic for doing these for us!
The original topper has pre made holes that make the right side down and the left side up. Just like Laseriffics. That's probably why the people that own them have it that way.
I just want to say that the topper is a must have. If you have a Royal Rumble with no topper or using a cheap belt that you can get at Walmart, make the purchase for this topper by Laserriffic. You will not be disappointed and by the sounds of it, this might be the first and only run by Laserriffic!
Quoted from Nightmare:this might be the first and only run by Laserriffic!
Replace might be with " IS ".. lol Thanks a bunch, it was a fun and interesting project and I learned a few things along the way.
Just got mine dropped off at the door a few minutes ago and it's completely awesome! I won't have time to mount it up before I leave for the weekend, but will post a pic of it in place next week. Really impressed with the quality and workmanship! Thanks again!
Don't mean to hijack the topper discussion but does anyone have any ideas why my machine would be slam tilting randomly? I am in the middle of a game and it stops and says slam tilt.....I put cardboard between the switch yet it still happens. Doesn't happen always but is becoming more frequent....any ideas???
The shaker goes off when it is supposed to.....but doesn't slam tilt it all the time. If this is the case, how do I allieviate that?
Quoted from Guzz4851:Don't mean to hijack the topper discussion but does anyone have any ideas why my machine would be slam tilting randomly? I am in the middle of a game and it stops and says slam tilt.....I put cardboard between the switch yet it still happens. Doesn't happen always but is becoming more frequent....any ideas???
It's very likely a problem within the switch matrix. I'm having a similar problem on my DE Batman, and have taken a crash course in troubleshooting the switches. It's really a pain if that's the problem, but relatively easy to fix once you identify the source of the problem. It's possible the slam tilt is being triggered by another switch. On my Batman, the center pop bumper is registering as the slam tilt. Sometimes it's as simple as a bad diode on one of the switches. With my Batman, I've sourced it back to a transistor on my main CPU board (and apparently all the resistors in line with Column 7 of the switch matrix - as they're all acting strange.) The parts are just pennies to order, but requires soldering new components on the board. Not bad as long as you're comfortable with doing that type of work.
First thing to do is go into your switch test mode and manually trigger all the switches and see if they show up correctly on the DMD. In the case of a bad row or column, often times it will trigger one or more switches at the same time, sometimes the correct one, sometimes incorrect. At least that will help identify which switch is problematic, then you can use a multimeter to test the diode(s). If all else fails, you can test the rows and columns right on the CPU board itself if everything under the playfield checks out.
Here's a great web site I've studied endlessly the past few weeks. It's an awesome resource! http://techniek.flipperwinkel.nl/desega/index3.htm
So...anybody interested in a new left ramp? Tsskinne is sending me the left ramp for me to model a new one.
Quoted from mima:Does anyone know the correct adjustment of the diverter on the back ramp? The one that diverts the ball down to the banzai or let the ball do a full outer lap...
Cheers
/mima
bump..
Quoted from Freeplay40:So...anybody interested in a new left ramp? Tsskinne is sending me the left ramp for me to model a new one.
Definitely interested in a new left ramp for my WWF. Those very much needed on many games.
Yup I definitely need one
Could use a new left ramp as well . Does anyone know how to find cliffys ? I did not see them on there site. Thanks for any help.
Quoted from Buzz:Could use a new left ramp as well . Does anyone know how to find cliffys ? I did not see them on there site. Thanks for any help.
Just email Cliffy, he has them or will make you a set for sure.
Quoted from Tsskinne:Just email Cliffy, he has them or will make you a set for sure.
Thank you so much. Iam so excited!!!
Thank you again. What a great guy sent him a message yesterday and he replied same day and I placed order.
No problem. I have had same experiences with Cliffy. He hooked me up with some of the first protectors for my Wrestlemania LE. Very thankful.
Quoted from mima:bump..
Mine is out on location now or I'd check. As I recall, in Banzai mode it goes all the way around. It can divert to the mini play field as well. I remember needing to adjust mine but can't remember what exactly I did...can anyone else help out here?
Thanks Kreator, nice read and helpful.
Does anyone have an extra prototype translite they are looking to sell?
Quoted from Laseriffic:Thanks everyone...I do have 2 left and the prototype.
I'm in for one. PM sent.
Pete
Quoted from Nightmare:Nice looking WWF Skywelker! I like it next to JP.
Me too...Dope DE setup right there!
Quoted from RDReynolds:Mine is out on location now or I'd check. As I recall, in Banzai mode it goes all the way around. It can divert to the mini play field as well. I remember needing to adjust mine but can't remember what exactly I did...can anyone else help out here?
Check how steep your machine is, and how strong the flippers are...Also the diverter on the banzai ramp might need adjusted.
Sometimes on Banzai mode the ball goes all the way around, sometime it diverts to left flipper...Seems to depend sometimes on how much speed the ball has when it hits the ramp; my flippers are pretty powerful, so even at 6.5 degree of slope, it still shoots around quickly if hit right.
Sorry for delay guys. Ramp was just sent via UPS. Mine isn't perfect but I hope it's good enough for a model. If it isn't I hope someone else will step up and send your ramp in. -Tommy
Quoted from Tsskinne:Sorry for delay guys. Ramp was just sent via UPS. Mine isn't perfect but I hope it's good enough for a model. If it isn't I hope someone else will step up and send your ramp in. -Tommy
Thanks for doing this TSSKINNE! Look forward to getting updates on status of this. A new WWF ramp would be awesome.
Received the left ramp today from Tsskinne and with it and the photos on Page 9 (Thanks indirectly to Chet) I think I have enough to reproduce these.
Quoted from Chet:Sweet. Is the plan still to reproduce the ramp using SS?
No, I'm not doing stainless...too expensive. Mine will be like the originals...Clear PETG.
This page was printed from https://pinside.com/pinball/forum/topic/wwfrr-club/page/10 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
