Solution Edit: Pinsider shimoda was able to fix the board and his process on the fix is below.
Older Edit: I've narrowed it down to the CPU board, please see post 16, any help is appreciated.
Hey everyone. I just purchased a WWF Royal Rumble that is acting weird. When I turn it on, it makes the sounds like everything is normal, but then the DMD goes blank. If I open the coin door, it seems to work, then goes blank again. The sounds will play in the background like normal. If I put in some quarters, it will allow me to play a game, but say during the end game "match" sequence, the screen will go blank again. Also, if I hit the adjustments button, it will say adjustments menu, but not let me do anything beyond that.
Here's a video of me turning it on and opening the coin door.
Thanks for any help!
