Quoted from dyno:Just wondering the green wire, white and purple wire and the end of the one diode, what are they connected to? Looking at the picture I can't tell if it's the microswitch or to the cabinet.
Looking at the switch from inside facing the the coin door, The white wire goes to a solder lug on the left side of the switch that is closest to the coin door, and the green wire is soldered to a lug directly in front of the white wire lug. The unbanded side of the diode is soldered to the same lug as the green wire and the banded side of that diode is soldered to switch lug above the yellow wire. the yellow wire is connected to a lug on the bottom of the switch using a quick connect type lug. Again, with a switch in hand, this would be much clearer.. The red wire and the banded side of a diode are connected to a solder lug that is screwed into the side of the cabinet, opposite, but near the switch.. the other end of this diode is soldered to a lug on the top of the switch, by itself.
