New! Dark mode!
(Topic ID: 163553)
WWF Royal Rumble - Slam Tilt Issue
By Guzz4851
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by Wariodolby
#1 4 years ago
Hello all,
I'm having a WWF Slam Tilt issue....
Below is a breakdown of what has been attempted. I am no expert in any of this. Any advice you may have or suggestions would be helpful on how to possibly remedy this very, very frustrating situation.
SLAM TILT KNOWN FACTS:
At first, I thought it was the slam tilt switch on the coin door so I put some cardboard between the switch thinking that it would stop....no.
Then, I checked all switches in switch test and took glass off to try the various switch combinations to try and replicate the slam tilt.....nothing.
Then, one day while playing, I hit the left flipper button and the machine registered a slam tilt.
I narrowed it down to the left flipper button...depressing that is what seems to cause the slam tilt (at random times).
I checked every diode orientation on the slam tilt row and column and all bands on the diodes are facing the same way.
I checked every diode with a meter and all, including the switch diodes when activated, read in the .5 range.
I checked the flipper board diodes inside the cabinet...all had a reading .4 to .5
I checked all diodes on the switch matrix board in backbox...all had a reading from .475 to .5
I checked for loose ground wires, nuts, etc. and tightened everything. Nothing more I can find.
I went to switch test and watched the DMD as I was pressing ONLY the left flipper button....after repeatedly pressing it 50 or so times, very quickly I saw on the screen Switch #7 (slam tilt) activate. When I continued to press the button, it wouldn't happen again for like 100 tries. Very random, doesn't always activate at the same time.
I put glass on, closed coin door and started a game. With the ball still in the shooter lane, I randomly pressed the left flipper button and after awhile, SLAM TILT. No other drop targets etc. were activated.
I proceeded to play a game again, was able to finish my game, but couldn't get it to slam tilt. I had a party, played it for hours, no problems.
Played the next day and after about 15 min.......SLAM TILT. This problem is very random and seems to happen when it wants.
I am completely out of ideas....Any suggestions you could provide would be helpful. Very frustrating. If there is something I am doing wrong feel free to guide me. I am definitely not the best "tech" but I am more than willing to learn. Thank you very much.
#2 4 years ago
Take it out of the circuit completely.
Remove one of the wires from it,then try all your test again.
I would say it's a flakey diode.
$ 16.00
Hardware
Filament Printing
$ 27.00
Filament Printing
Peachtree City, GA
Professor Pinball
PinSound
Gweem's Mods
$ 99.00
Arcade Upkeep
$ 19.00
