None of the insert lights in the mini play field are working and I have no manual or schematics. Can someone point me in the right direction. I have no clue as of where to look in the Data east games. Thanks.
There aren't many Data East guys around here, and the ones that are may be getting distracted by your avatar and forgetting what they were here for.
Did you run through the lamp tests in the menu? What were the results?
When was the game last working fully, and what has happened since then?
if only the mini playfield isn't lighting up would suspect like a loose or bad connector to it. Just my opinion. i wouldn't think its a board issue or anything
I have a WWF for sale on eBay (UK) I'll check out the connections / schematics. I have had several DE machines (about 20) and repair the CPU boards so should be able to help you solve this, bear with me I will look tomorrow for you (bear in mind I am in UK) so hopefully have answer on here before you wake up Sunday
Regards
Brian
Thanks! I took the mini playfield of and checked all connectors and wires but all were snug. There was some insulation a one wire that had worn down to the wire but still in tact. Would Mathis do it or am I looking at a burnt transistor?
Just checked circuit diagram a these lamps are on Column 7 so check transistor Q65
and Yellow/Violet on CN7 8 to make sure it's connected. Suspect Q65
Cheers
Brian
This page was printed from https://pinside.com/pinball/forum/topic/wwf-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
