(Topic ID: 155356)
WWE Wrestlemania Club
By TouchingEvil
7 years ago
  • 915 posts
  • 103 Pinsiders participating
  • Latest reply 3 months ago by LesManley
  • Topic is favorited by 18 Pinsiders
There are 915 posts in this topic. You are on page 19 of 19.
#901 9 months ago
Hello all, I just updated my wrestlemania to the latest code. Just wondering if there is any good explanation out there on which character to pick. I see that Cena has 3x pin value but I don't notice it. Do you have to get the lit upper lane to activate this? I haven't seen a great tutorial on this game with the new code. Any points to the correct direction or answers would be greatly appreciated.
Thank you,
Jared
#902 9 months ago
Quoted from Edenecho:
Cheers fellow wrestlers!
Last tournament my WWE pro started struggling with the autoplunger, it didnt have enough force to sed the balls all the way up to the top.
I changed the coil sleeve, and cleaned the coil stop (it is kinda welded into the whole bracket, so not easy to remove). That helped for a while, but then it started struggling again.
has anyone experienced the same, and do you know a stronger coil I could swap out with, for more juice?
PinMonk any ideas on the coil? (PS: no idea why a "blank" image is embedded)
#903 9 months ago
Quoted from JustJared:
Thank you,
Jared
I own a wwe pro and have plans to make a tutorial.
But what activates the ability is to shoot left lane, left inner orbit and right inner orbit, while in a match. With cena you will see the pin value jump from 5ish million to 15 million when its activated.
#904 9 months ago
Quoted from Guinnesstime:
What about the autoplunger forks? Have they bent outward so they aren't hitting the ball evenly on both sides? Is the autoplunger fork mechanism sloppy left to right on the pivot pin? (You can put washers in to reduce the slop).
If that's ok, I would check the resistance of the coil using a multimeter in the ohm position. You may just have a coil that's headed out to pasture and needs to be replaced.
#905 9 months ago
Just noticed my WWE LE that I got second hand is missing the Hulk Hogan signature on the apron. Does anyone know if these can be purchased through Stern or something along those lines.
20210808_185948 (resized).jpg20220617_122912 (resized).jpgScreenshot_20220617-151420_Chrome (resized).jpg
3 weeks later
#906 8 months ago
Quoted from Coolpinballdino:
Probably not, but I would be curious if you actually could. Maybe you could get the blank plate? Best bet might be just getting Hogan's signature on your own and adding it.
3 weeks later
#907 7 months ago
Hi guys, big pin fan and big WWE (more the older Attitude era) so the LE is very tempting, these pins are hard to come by in the UK, I have a lead on a nib LE in Italy but before I pull the trigger (as its 9k euro plus (post brexit ffs) Import tax) whats the crack with the code, I head it was unfinished? Any opinions on mods like colour dmd, has that been done? Sorry as the answers are probably in the 900 posts before this one!
OOOOOOOHHHHHHHHHHHH YYYYYEEEAAAAAHHHHHHHHHH!!!
#908 7 months ago
Quoted from JonCrox:
Color DMD has not been done yet, but it was being worked on when I asked about it. Who knows when it will be completed. The code is "finished", as it's all there, but it needs some work. For instance, Royal Rumble and the Intercontinental Title start on top of each other, on the LE one of the controlled gates never closes making it really hard to complete things in the ring up top, Ref Multiball as it sits is worthless and there is even a Combo Champion high score that never gets displayed and you wouldn't know existed unless you got 15 or more combos. Even once you get the Combo Champion high score and put in your initials, you'll never seen it in the high scores. At a bare minimum how hard would it be to display that Combo Champ score that is already programmed in and/or have a high score list for each wrestler like they do for houses in Game of Thrones? It's a fun game as it is for me, but it could really be good with just a little polish. Sad to say I wouldn't bet on it ever getting it though.
2 months later
#909 5 months ago
Joined the club today with an LE. For those that hate on this game, "I got two words for ya..."
#910 5 months ago
Forgot to post a pic...
#911 5 months ago
Ok my Wrestlemania brothers I need some help. Is it easy to get off the upper playfield? I looked in the manual and it didn't look obvious to me. I have a switch that lost a screw that I need to get back in there, but I don't think I can do it without removing something. I circled it in green, this view is with the playfield up, so it is on the right side. It's not the one in the foreground, it's in the background of the green circle. Has anybody tackled something like this before in there game and/or have any suggestions on next steps? Appreciate the help!
#912 5 months ago
Quoted from LesManley:
I did a step by step on post # 484. It's pretty easy and takes 15 minutes. It gives you a chance to get everything under there clean.
#913 4 months ago
Ok guys. Almost have the game back together. I noticed the two targets underneath the ring have the wires disconnected. The one on the left has one wire disconnected and the one on the right it looks like the metal tab is broken and it has three wires disconnected. Does anybody have any pictures on how these are supposed to be wired up? I want to make sure I get it right.
1 month later
#914 3 months ago
74ABA8D4-9E47-4085-AA09-7C4FCDDFE4B1 (resized).jpeg96EC088F-DC6B-42AE-9391-4E426E75C03F (resized).jpegAE80F843-E3EA-45B0-97E9-1226214FB6BF (resized).jpegD828AFA5-771D-4BFB-9FC6-521EEDD6D6AD (resized).jpegDA34C444-0D78-41DD-984B-98AB9A5D36B1 (resized).jpeg
#915 3 months ago
Quoted from tatman9999:
[quoted image][quoted image][quoted image][quoted image][quoted image]
Thank you!
$ 6.00
Apron Envy
Protection
$ 54.99
Shooter rods
$ 54.99
Shooter rods
$ 65.00
PinballReplacementParts
Arcade Upkeep
Other
$ 52.99
Pinball Shark
Shooter rods
$ 18.00
Pin Monk
Other
Men
$ 12.50
Protection
$ 76.00
Lighting - Backbox
Arcade Upkeep
Backbox
Gweem's Mods
Sound/Speakers
$ 29.99
PR Mods
Sound/Speakers
$ 69.99
Pinball Shark
Shooter rods
$ 6.00
Pin Monk
Other
This page was printed from https://pinside.com/pinball/forum/topic/wwe-wrestlemania-club/page/19 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
