Just to keep the pressure on a little I've e-mailed Stern's bug report e-mail ([email protected]) about the broken code in Wrestlemania. I would suggest others do as well. Hopefully at a bare minimum, they will address the broken code at some point in the future.
This is what I wrote...
"There are a few major bugs in Wrestlemania that need to be resolved, the code is broken how it sits now.
Primarily, Royal Rumble starts over the Intercontinental Champion match. Once you start the IC match, the first ramp you hit starts Royal Rumble, which it isn't supposed to happen and eliminates the IC match. The IC match should be some version of the current Royal Rumble MB, with just single ball play and only 2 shots required to each lit shot instead of 4. Then the Royal Rumble should be it's own MB and those rules should be similar to the rules for the MB on the instruction card.
Second, in the Royal Rumble MB, the controlled gates at the top of the game stay open (1 on Pro, both on LE). The pin in the ring is required 5 times to finish the MB and it has to be finished to get to the Heavyweight Championship Match, but with those gates open, the ball doesn't go to the ring. It's a problem for the Pro with the one gate open, but it makes the LE essentially impossible with both gates being open for that MB.
Third, many times the Tag Team Multiball Total will report a total for the MB that is higher than your current game score, which of course isn't possible. This was the same issue that happened on Ghostbusters with the Gozar Champion score being shown that was higher than the total game score.
Fourth, there is a Combo Champion high score that you can enter then you get 16 or more Combos in a game, but once you enter your initials, that high score board is never seen again during attract mode or in instant information. The high score chart needs to be made visible.
Finally, Instant info should have number of current Money In The Bank shots (there is no way to know during gameplay otherwise), number of combos, current bonus amount and maybe even next pop bumper hits award."
I also added...
"There are a lot of little things that could be tweaked to take the game to the level it should be, even just small things like adding a high score table for each wrestler, but the above bugs (especially the first 4) really need to be addressed as the game isn't just incomplete with those issues, it is broken as it sits. As a Wrestlemania owner for years now, I really hope you will come through for all the owners and fix the code so the game isn't broken."
