Quoted from waynetrane:The final decal version installed ![quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Can't wait to get mine.. its gonna feel.like a new game.
looks awesome. Did you make those yourself?
Quoted from waynetrane:Yes i did.
I missed the factory feeling.
When will you start to ship them?
That's great work I love how it looks to bad I bought mirrors blades before these came out which looks awsome as well and helps to with the lighting better on such a dark game.
I notice that people seem to love all the mods for WW, particularly the Modfather and Mezel ones, however I notice that no one has installed the chocolate waterfall river mod that goes over the Wonkavator exit?
has anyone bought and installed that one? I am curious as to how it actually looks on the playfield.
Quoted from JediPimp:I notice that people seem to love all the mods for WW, particularly the Modfather and Mezel ones, however I notice that no one has installed the chocolate waterfall river mod that goes over the Wonkavator exit?
Like poop.
We just recently got a WW LE for the showroom and is my go to game when I take a break or after locking the doors at closing time. I love it!
I’m Enjoying trying to figure out the rules. Today I figured out how to add Candy to the Candy Jar. Gotta push the flipper buttons to light the in-lanes just as the ball is dropping from the ramps, clever.
AECF8A8C-6375-4A36-94D6-307A2630E2D7 (resized).jpegQuoted from mtp78:Any freshly made wonka le s around or they going straight to making ce s ?
Just received mine October 13th
My LE is showing up tomorrow, just off the line my dist. tells me..... besides the playfield issues, Anything mechanical to look for with a new owner ?
Quoted from mtp78:My LE is showing up tomorrow, just off the line my dist. tells me..... besides the playfield issues, Anything mechanical to look for with a new owner ?
Check height of gold bolts below lockdown bar
Scour bottom of cabinet for extra random hardware floating around (check speaker magnet too)
Adjust shooter housing to prevent clearance issues with shooter tip hitting auto-plunger
Check Augustus spinner for correct position and clearance for good spin
Ensure Factory ramp deflector is installed
Install left outlane guide post, moving rubber from inlane post over
Check switch gaps on slingshots (both mine needed adjustment - too tight)
Check trough board switches in switch test, be prepared for a failure
I'm missing some stuff - I'll add later when I remember
-wonka owner #08742206, play field #105, clear coat case #5107
Quoted from smalltownguy2:Check height of gold bolts below lockdown bar
Many of these things were addressed allready. Still a good list to check
Quoted from bigd1979:Many of these things were addressed allready. Still a good list to check
Well ... one thing not listed ... the start button needs to be pushed to see if the game starts ... you never know, so keep trying it. I try to check that at least a couple times a day. Yep - it's still working.
Sorry if it's already been mentioned but ball is having trouble making the boomerang ramp on auto-launch. Strengthening the spring doesn't seem to help. Is there an easy solution?
What do you mean here about the the gold bolts? Also, is anyone else having a problem with their lockdown bar? Mine takes a lot of effort to lock into place, and often requires a few minutes of jimmying until the mechanism fits/looks properly.
Quoted from BigSilverPin:What do you mean here about the the gold bolts? Also, is anyone else having a problem with their lockdown bar? Mine takes a lot of effort to lock into place, and often requires a few minutes of jimmying until the mechanism fits/looks properly.
You can adjust the lock bar mechanism with the two screws under the lock bar.
The JJP lockdown bars seem really finicky. I have lots of issues with WoZ and Pirates. WoZ I adjusted the brass screws, made a bit of a difference, still takes some finagling every time. Pirates refuses to latch closed with those screws all the way down or all the way up or any state in between, but thankfully doesn't really move anyway. Wonka and Hobbit lock down pretty well, but still rarely as easy as a Stern bar.
Quoted from VALIS666:The JJP lockdown bars seem really finicky. I have lots of issues with WoZ and Pirates. WoZ I adjusted the brass screws, made a bit of a difference, still takes some finagling every time. Pirates refuses to latch closed with those screws all the way down or all the way up or any state in between, but thankfully doesn't really move anyway. Wonka and Hobbit lock down pretty well, but still rarely as easy as a Stern bar.
Thank you to you and Lermods for the quick answer! I thought it was me, everytime I close it it's so stubborn. I'm presuming thats what the two brass screws are for! thanks guys!!
I had to reset, adjust my receiver for Pirates, to get the playfield to sit properly, as well as the yellow latch to sit in place. It's maybe a good idea to check your alignment by shifting the receiver itself, by removing the mounting bolts that sit outside the front of the cab. Then you can slide the receiver a bit and adjust as necessary.
I assume this is just an issue with my machine (which has had over a half dozen issues already), but do anyone else's flippers "chop" when the ball is coming at them at high speed? Particularly my right flipper. By chop I mean when a ball is coming down fast and you hit it, it doesn't travel back up the playfield smoothly, instead the ball does a little hop first. Kind of like hitting a sharp grounder to second base or something. Could it be the flipper isn't perfectly parallel to the playfield? Could just be the ball is picking up a strong spin that's making this happen, too.
Quoted from wesman:I had to reset, adjust my receiver for Pirates, to get the playfield to sit properly, as well as the yellow latch to sit in place. It's maybe a good idea to check your alignment by shifting the receiver itself, by removing the mounting bolts that sit outside the front of the cab. Then you can slide the receiver a bit and adjust as necessary.
Will give this a shot, thanks!
Quoted from KingBW:Well ... one thing not listed ... the start button needs to be pushed to see if the game starts ... you never know, so keep trying it. I try to check that at least a couple times a day. Yep - it's still working.
Tell me about it.. ive played more pinball in the past month or so then i have in the past year.... all bc of wonka.. it so dam good
Quoted from VALIS666:I assume this is just an issue with my machine (which has had over a half dozen issues already), but do anyone else's flippers "chop" when the ball is coming at them at high speed? Particularly my right flipper. By chop I mean when a ball is coming down fast and you hit it, it doesn't travel back up the playfield smoothly, instead the ball does a little hop first. Kind of like hitting a sharp grounder to second base or something. Could it be the flipper isn't perfectly parallel to the playfield? Could just be the ball is picking up a strong spin that's making this happen, too.
Usually the flipper rubbers need ajusted on the bat better. To high or to low can cause issues
Quoted from adamross:Sorry if it's already been mentioned but ball is having trouble making the boomerang ramp on auto-launch. Strengthening the spring doesn't seem to help. Is there an easy solution?
Boomerang ramp on launch? Also the spring has nothing to do with the auto launch.... sounds like it may need ajusted.... or try setting the power up in the settings.
A tidbit of information told to me by the Mechanical Engineer at JJP at Expo: He had to design the gobstopper to be the same exact shape(s)/designs and colors as what was in the movie and required approval by the license holder. The gobstopper plunger on the CE has the same exact design/colors as the gobstopper in the game, just a reduced size. I thought that was being pretty picky (or contrary - meticulous), but interesting to know.
I'm glad that Ted's idea didn't fly that at some occasions during the game the gobstopper would grab the ball and consider it a drain (ball over). That would be something new to pinball, but the game is hard enough. Interesting idea though. (This was in the Expo Saturday presentation.) It is pretty cool that the team at JJP bounce ideas off of each other and work together on projects.
I did like the idea that they showed for a concept design for the current captive ball being another physical ball lock instead. Once the second ball is locked, it was also a captive ball device until the balls were released. That would have been pretty cool. Interesting stuff and cool that they shared that with us.
I tried to watch the jjp expo video on YouTube but there is no sound . Is it just me having issues? Can anyone else hear it? I wanna see / hear the early Wonka pics and info.
Quoted from bigd1979:I tried to watch the jjp expo video on YouTube but there is no sound . Is it just me having issues? Can anyone else hear it? I wanna see / hear the early Wonka pics and info.
You mean MGC. Try this one:
Quoted from KingBW:That would be something new to pinball
Actually, it's really really OLD. And it probably would've happened if we could've presented it in a more understandable way.
Quoted from toyotaboy:You mean MGC. Try this one:
Nope.. they did a expo q@a and it has no sound for me..
Quoted from bigd1979:Nope.. they did a expo q@a and it has no sound for me..
Ya the one linked has no sound for some reason.
Quoted from Gumby510:Ya the one linked has no sound for some reason.
Ok.. if anyone has a good video off jjp at expo please let me know.
Quoted from bigd1979:if anyone has a good video off jjp at expo please let me know.
Youtube one has audio.
Quoted from pinball_keefer:Actually, it's really really OLD. And it probably would've happened if we could've presented it in a more understandable way.
I haven't seen a ball drain in the middle of the playfield before. Must be from the EM era? It was still really interesting to see the concepts. Thanks for sharing that. I am also going to try that coin op mode on my pin at a party (like we discussed at Expo) in a couple of weeks with a bunch of non-pinhead friends that like our JJP pins. At a set time during the party I will backup the settings, change to the coin op settings and let them experience the modes that they likely didn't achieve for the previous 3 hours. That should be fun for them. I really want to see their reaction to the change. Thanks to the software team for thinking about that. Then, the next morning, just restore my settings and we're back to where we were.
Quoted from bigd1979:Not on my end....
Audio is working on Youtube, and when you play it from Pinside.
Quoted from bigd1979:Ill have to try threw my pc or tv.... but it will not work on my phone. Very odd
I had the same problem,but worked fine on my Ipad and tv
The sound is really low (for me) and you have to turn the volume way up.
Quoted from romulusx:I had the same problem,but worked fine on my Ipad and tv
Yep works fine on wife's iphone.. just not my phone... weird..
I see that some ledboards has empty "spotlight" connectors.
Is it possible to plug some extra spotlights in these boards?
I would like to ad 2 extra spotlights to light up the middle playfield.
Quoted from pascal-pinball:I see that some ledboards has empty "spotlight" connectors.
I don't think it will work right. You can tap into the existing spots, they are all on the same board, but dont think you can plug into the other boards where there are open headers labeled "spotlight" and get a steady light. I've tested it and haven't had good results.
I guess I cut my teeth on incandescent older machines.
Wonka SE with the backboard light mod seems plenty lot to me.
With the backboard lighting and the Mezal Mods factory divertor mod I feel like my SE is what it should be,the only other thing I’m thinking of doing is the Lermods Wonkavator.Waiting for Black Friday for discount. Hint Hint
Quoted from romulusx:I guess I cut my teeth on incandescent older machines.
I wish I could discount the wonkavator, but it's a joint venture and I don't get much from it. It's a lot of labor to make and wire it.
Quoted from Lermods:I don't think it will work right. You can tap into the existing spots, they are all on the same board, but dont think you can plug into the other boards where there are open headers labeled "spotlight" and get a steady light. I've tested it and haven't had good results.
maybe some of the modders can make this?
2 small white spots/leds with an Y-splitter to hook up on the other spots/leds.
Quoted from pascal-pinball:maybe some of the modders can make this?
Been working on it...just have to make a cover for the brackets so they blend in.
https://pinside.com/pinball/forum/topic/wonka-mods-what-does-the-game-need#post-5283026
Anyone mess with the backbox monitor color settings? Was playing some di last night and its monitor seems much shaper and vibrant. How and where do u even mess with the settings.... anyone have any experience with this?
This page was printed from https://pinside.com/pinball/forum/topic/wwcf-club-wonka-golden-tickets-inside/page/62 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
