Quoted from PinWoofer:The KO+ amplifier output is pro level, so it is "hot" compared to standard consumer level which is likely what you are looking for. So, we strongly recommend adding our Line Trimmer gadget which gives you control over the level sent to your streaming device input (same goes for an external sub). Start with the level out at zero and increase until you have a measured / clean input during your livestream.
You can use the master volume on the amp to turn down the level of the machine without affecting the level to your streaming device (because the amplifier ouput is derived from the preamp, but the master volume controls the game level only).
If you want to substitute the 12ft cable out from TRS to RCA, to TRS to TRS, please make a note in your order or PM me so we know.
Below is the stand-alone item link with the complete write-up, but you can add it to your kit when you order and get a bit of a discount:
https://pinwoofer.com/pinwoofer-line-trimmer/
Great question!
I’d been meaning to ask (and still didn’t understand from this answer) why is the line trimmer a must with the external sub? I think I just ordered the line trimmer for my wonka kit, but I’ve got a spike kit that came with one of my pins where i attached the sub to the sub out on the card in the back box. Should I have done that differently?
