Hammerhead Thank you- did you put to posts on the left? Where that black rubber cap is? Thank you
Quoted from ktcoady12:Hammerhead Thank you- did you put to posts on the left? Where that black rubber cap is? Thank you
Yes, that’s where you put the extra post to tone down the left drain difficulty. You can put it in the lower or upper slot. Upper slot makes for easier difficulty setting.
Just got my machine, 2019. 3 of the 4 mini spotlights are out. Is this a typical part that goes bad and is JJP the only option short of replacing the led bulbs myself?
Quoted from rob3:Just got my machine, 2019. 3 of the 4 mini spotlights are out. Is this a typical part that goes bad and is JJP the only option short of replacing the led bulbs myself?
Ditto
I think the game is to dark,I realize simple self make stadium lighting May minimize some lighting affects but for 25.00 I recommend them and they are rgb if you want to change or mix color.
It would be strange to have 3 led bulbs defective. It could be wiring, or a board, or they're just not seated properly. Either way I'd do some quick troubleshooting and contact JJP. On principle I struggle with fixing out of pocket a NIB $11k pin myself. The fact that Green Machine had the same issue makes me think it's not the LED themselves.
Got my game December 2019, lost one spotlight LED so far which I replaced. Ordered the full assembly from JJP (wire+LED)
Quoted from ktcoady12:Hi All= newer WONKA LE owner- General question for the outlane posts - particular the left side- The bounce on the post is brutal- tons of left outlane drains- How do you all have your post or posts set on the left? Mine came from the factory with the left post centered in the middle over the lane divider-
A lot of people will add that extra post in the goodie bag (cheater post).
You dont always have to remove rubber. Best to try it out with all on, and then reduce as needed.
Quoted from arcyallen:It would be strange to have 3 led bulbs defective. It could be wiring, or a board, or they're just not seated properly. Either way I'd do some quick troubleshooting and contact JJP. On principle I struggle with fixing out of pocket a NIB $11k pin myself. The fact that Green Machine had the same issue makes me think it's not the LED themselves.
I swapped them around. All the spots are good, the 3 bulbs are bad. Agree strange. I have stadiums on so they really don’t do much but I don’t like having lights out. May just replace the bulb myself. Seems like it would be simple enough.
4D228F67-25CB-4364-90FF-9F54483F5C0A (resized).jpeg5AEB9F84-C47C-4D3F-AB5E-D0493F9F70BC (resized).jpegQuoted from arcyallen:It would be strange to have 3 led bulbs defective. It could be wiring, or a board, or they're just not seated properly. Either way I'd do some quick troubleshooting and contact JJP. On principle I struggle with fixing out of pocket a NIB $11k pin myself. The fact that Green Machine had the same issue makes me think it's not the LED themselves.
My bulbs are bad too. I tested them
Quoted from Rager170:A lot of people will add that extra post in the goodie bag (cheater post).
Yes, I tried to keep all the rubbers at first but the ball would get stuck in the outer inlane
Quoted from allsportdvd:Hi all.
Does anyone have the official Topper pictured below for sale? I'm happy to pay shipping out to California where I'm based till mid-late April
Automated still has them I think. Best to call first to verify if they actually have them. No idea what the original price was but I'm sure they jacked it up a bit.
Quoted from solid_snake:Automated still has them I think. Best to call first to verify if they actually have them. No idea what the original price was but I'm sure they jacked it up a bit.
https://www.coinoppartsetc.com/product/games-parts-pinball-machine-parts/jersey-jack-willy-wonka-limited-edition-pinball-machine
Saw that but trying to avoid $499 for the topper if I can
I thought it used to be $299 but not positive.
Hey everyone. Wondering what size washers to use for the various posts up top and the sides of the playfield? The lower sling posts have black washers from the factory, my build was around 6 months ago. I didn't check if they were plastic or metal yet. Any info on what most people are buying?
Quoted from wisemanbba:Just got an LE. Can I get some thoughts on must have mods for this? Favorites? Thanks
Don’t get the pile of chocolate blocks the light on the center ramp.
Quoted from Rager170:I thought it used to be $299 but not positive.
It’s $499 on their site
$299 would be ideal
Hey can someone point out where each of these led bulbs are on the playfield? I see three. One shines on the gobstopper, one shines on the camera, one near right sling shining on playfield, but can’t find the 4th
Quoted from SBrothers:Hey can someone point out where each of these led bulbs are on the playfield? I see three. One shines on the gobstopper, one shines on the camera, one near right sling shining on playfield, but can’t find the 4th
There are 2 behind the gopstopper on my machine. One points to the camera and the other points towards the Wonkavator.
Quoted from JohnTTwo:Don’t get the pile of chocolate blocks the light on the center ramp.
Why?
I have the chocolates to help protect errant balls from striking the camera and oompa loompa. I've seen how those can get damaged. But it doesn't block the light on the camera, which is coming at it more from the side than straight on. Plus, I like the look.
https://pinside.com/pinball/market/shops/1012-ulekstore/02705-pile-of-chocolate-bars-mod-for-jjp-s-willy-wonka
Quoted from rob3:I swapped them around. All the spots are good, the 3 bulbs are bad. Agree strange. I have stadiums on so they really don’t do much but I don’t like having lights out. May just replace the bulb myself. Seems like it would be simple enough. [quoted image][quoted image]
Where can I get those 2 and 4 wire connectors for under the playfield that are used by the lighting and spotlights?
I have this mod and think its great for protecting that area.. it might not protect the camera as well as the chocolate bars you showed..
https://pinballmods.co/willy-wonka-pinball-jjp/wonkavision-stage-captive-ball-protector
Quoted from judremy:Where can I get those 2 and 4 wire connectors for under the playfield that are used by the lighting and spotlights?
JJP has them for $10.99. Have to contact them direct.
Quoted from allsportdvd:It’s $499 on their site
$299 would be ideal
Yea. Cause at $250 this is pretty cool….
Quoted from c818919taylor:Yea. Cause at $250 this is pretty cool….
https://eight3five.com/products/preorder-iron-studios-willy-wonka-deluxe-art-scale-1-10?variant=37626925383836¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&cmp_id=13915992170&adg_id=128451467201&kwd=&device=m&gclid=CjwKCAjwrfCRBhAXEiwAnkmKmTg7-xWqdPaWv-5ESIskBlvI88XcZtP38RSoivWI6LnQPspnpLa3ChoCMLQQAvD_BwE
Would be cool. Dimensions dont work for me.. almost 10 inches high..
Dude, thank you for this link. I ended up getting one from bigbadtoystore.com. Looking forward to seeing it in person.
Quoted from seenev:Anyone else ever get two balls in here and have them get stuck?
Yes and no
Quoted from c818919taylor:Has anyone's shooter rod hit the autoplunge? And how did you fix it?
3 screws for the shooter assembly, loosen and adjust so it's hitting the ball center. Confirm the autoplunger forks don't jump when you plunge.
Quoted from zaphX:3 screws for the shooter assembly, loosen and adjust so it's hitting the ball center. Confirm the autoplunger forks don't jump when you plunge.
Not perfect but far better. Thanks. Ill try again with the new shooter rod.
Quoted from c818919taylor:Not perfect but far better. Thanks. Ill try again with the new shooter rod.
If you have an aftermarket shooter rod, skull mod etc I believe you'll need a shorter external spring.
Is there a more cruel and infuriating moment in all of pinball than losing Wonka’s Office and getting berated by Gene Wilder? If so, I’d like to hear you try to name it.
Quoted from jackd104:Is there a more cruel and infuriating moment in all of pinball than losing Wonka’s Office and getting berated by Gene Wilder? If so, I’d like to hear you try to name it.
Best integrated callout in pinball, in my opinion. Makes me simultaneously mad and smile.
Quoted from gorditas:Best integrated callout in pinball, in my opinion. Makes me simultaneously mad and smile.
It makes me remove my headphones and look away from the game. Hah. I agree it’s great. Too great.
I honestly love it. Perhaps I need help
Where can you pick up the sticker that applies to the playfield back box? I’ve seen a few of these but can’t find where to buy them.
Quoted from zaphX:If you have an aftermarket shooter rod, skull mod etc I believe you'll need a shorter external spring.
Nope. Modelvisionary (Super Skill Shot Shooters) was dead on. Great product. Highly recommend.
F1A078D5-4BA1-4A30-9A9A-7F7E00C60AB6 (resized).jpegQuoted from c818919taylor:Nope. Modelvisionary (Super Skill Shot Shooters) was dead on. Great product. Highly recommend. [quoted image]
I'm a dummy and confused Guns with Wonka.
Quoted from zaphX:I'm a dummy and confused Guns with Wonka.
They both have fun and games. The biggest difference is "little surprises around every corner, but nothing dangerous" vs "Welcome to the jungle baby, you're gonna die!"
Much has been discussed about the tinny stock speakers. Has anyone replaced the backbox speakers with something off the shelf and, if so, what did you buy and how was the result? I am planning to add an external sub (Polk with pinnovators connector) so I’m just thinking about the backbox ones now and if I can improve them for a reasonable cost. Thanks in advance.
Good question. The sub helps but you still will have the tinny sound.
Quoted from jackd104:Much has been discussed about the tinny stock speakers. Has anyone replaced the backbox speakers with something off the shelf and, if so, what did you buy and how was the result? I am planning to add an external sub (Polk with pinnovators connector) so I’m just thinking about the backbox ones now and if I can improve them for a reasonable cost. Thanks in advance.
They are in my line of sight and during golden egg room you need to see what color the center ramp light is, don't want any bad eggs!
I hit pure imagination for the first time tonight! What a treat!!!!! Had no idea what to do but got that messed up pinball high feeling!!!
Quoted from seenev:13,000,000 and scorbit calls it the lowest score on earth...
Sorry about that. It's clearly a bug! We'll add it to the list.
Quoted from JohnTTwo:They are in my line of sight and during golden egg room you need to see what color the center ramp light is, don't want any bad eggs!
Oh, im not sure ive seen a mod that blocks the center ramp light.. Yea, thats annoying haha
Just had this tonight! Ugh. But so perfect!
Had my personal best score tonight too… 9,458,840. I was pretty happy but also ticked I didn’t break 10M!
This page was printed from https://pinside.com/pinball/forum/topic/wwcf-club-wonka-golden-tickets-inside/page/224 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
