Quoted from arcyallen:Alright, I've played about 30 games on my new LE (my first JJP!), and I have some questions for you all before I contact JJP.
-My machine moves a lot, I think due to the felt leg protectors causing extra space. I get a lot of tilts because of this. Are people just tightening the leg bolts a lot more, or what? I'm getting tilt warnings on every game, and rarely tilt on my other pins. I don't want to overtighten the bolts either.
-During a few features the machine buzzes a lot, especially at the beginning of the Elevator feature. I'm curious what mechanism is causing this. Is it a shaker, or something else in the machine? It feels pretty cool, but a little disconcerting as I'd swear something was wrong if it weren't so controlled.
-My kickback isn't syncing well with the ball, and only works half the time (and rarely correctly). I figured the machine might learn over time, but it has not improved. Should I start tinkering with the "do not tinker" coil settings section?
-I get balls stuck on the innermost left inlane between the rubbers. I can't think of any adjustment to make, and the rubbers haven't broken in enough to let a slow ball go through. If I give it a good shake it'll come loose, but clearly it's not right.
-Check your balls! One of my was badly rusted out of the box. Thankfully I noticed quickly.
This is an interesting pin. At first it was almost overwhelming because it's not super clear what to do. Most every other pin I've owned I could quickly figure out the gist of it. This one will take some time!
For the inlanes, if you have the extra posts installed, you will have a hard time getting a ball to pass cleanly with any standard rubber. The solution I found to work perfectly is post caps, with the closed end cut off. Slide them down to where the rings are currently installed, and they work perfectly. The bonus is, they look like little pieces of candy. You might be able to zoom in on the photo below to see. Not home for a close up.
https://www.titanpinball.com/index.php?route=product/product&product_id=52
When I set up my game, I presumed the felt was just for shipping. I didn't see until later that they were intended to be "protectors." This was a solution to a problem I've never had, and every machine in my collection has custom powder coat.
For the kickback, check to see how the rollover is bent. It sounds like the ball is activating the switch late (if it fires after passing.) It might need to be bent up, or forward a bit. I'm not home to check, but there might be a delay setting as well. If it fires early, it could be the opposite problem, or your game is pitched too shallow.
I presume that the vibration you feel is the shaker. Make sure everything is tight, and check your settings. I love the integration on mine.
