Had a screw fall out of diverter “plate” for Wonkavator - took a while to realize what was going on - long and short what a pain in the ass - there are 2 tiny machine screws that hold the diverted “plate” on to a coil post. One screw fell out and one completely
loosened up. Took 30 min to find that little SOB in the cabinet. Unless I’m missing something the Wonkavator assembly needs to be removed to get to this diverter. This operation wasn’t not too bad except for cutting the zip ties on the assembly wire harness. Once i got to the diverter I put a drop of blue lock-tight on each screw and hopefully it won’t happen again. Also if this ever happens to anyone else make sure to install the diverter plate back on the way it came off. If for some reason it gets turned around… the diverter post ends up on the wrong side and zero chance you would be able to tell just by looking at it. Turns out if you do accidentally put it on in the wrong orientation the opening isn’t enough for the ball to go through…… ask me how I know, or better yet ask me how many WTF’s were said trying to figure it out.
Anywho hopefully this is all I have to mess with for now and can continue to enjoy the game.
