(Topic ID: 240130)
Wonka Club - Golden Tickets Inside
By f3honda4me
2 years ago
  • 10,591 posts
  • 559 Pinsiders participating
  • Latest reply 1 hour ago by PlayPin
  • Topic is favorited by 234 Pinsiders
Topic poll
“What edition are you ordering or planning to buy?”
  • Standard 128 votes
    26%
  • Limited Edition 252 votes
    51%
  • Collectors Edition 116 votes
    23%
(496 votes)
WW autolaunch.pdf (PDF preview)
WW_Rules_Jan20.pdf (PDF preview)
12 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,591 posts in this topic. You are on page 159 of 212.
#7901 10 months ago
Yup. I’m pretty happy with the game that it’s worth seeing if anything is wrong with the update. I have zero interest in Scorebit, and the wireless offers me no value at this point.
#7902 10 months ago
Update done without problems. Now you can increase the brightness for Oompa Loompa Multiball; much much better now That alone is worth the update.
I mean a super-Spinner-shot-combo has been implemented (right in lane then kid Multiball lane and after that the super-spinner is activated for one shot).
Beside of that no big changes during Gameplay noticed.
I do not use the bt/WLAN option...for me no additional value; but maybe I am too old for that kind of things already
#7903 10 months ago
I can trace every game killing drain on this game back to the right ramp reject (due to a missed shot). It's amazing how what looks like the easiest shot on the playfield is the killer, for me anyway. It's either an immediate SDTM or a complete high speed loss of ball control, usually into the pops or quick outlane. Ugh. All that frustration, this is currently my favorite game (and it's sitting in between Pirates and GnR CE), I keep coming back even after new game honeymoons.
#7904 10 months ago
So, my Gobstobber target stopped working. Got the dreaded target open error message. On closer inspection, the top of the switch simply broke off. See the pic below. The arrows highlight the end piece of the switch I found in my ball trough.
I’ve only had the pins for about 90 days. First real issue. Would something like this be covered under a parts warranty? And if so, would appreciate any guidance in how I go about getting a replacement switch. Is there a claim process with JJP?
Thanks in advance for the help.
#7905 10 months ago
Quoted from LTG:
I didn't find any open USB ports on my motherboard. So I go a USB hub ( has four USB ports ) plugged it into the cable by the cashbox. Plugged the two dongles into it.
Works great. And still has a couple open USB ports in case I want to plug a USB stick into the cable for updates or for images.
Thanks. So you just plug them into the USB ports and nothing else. Isn’t there something in the software that needs done? Forget it. I got it.
#7906 10 months ago
Quoted from Goyomex:
Thanks in advance for the help. [quoted image]
I would bet JJP will help you on this issue. Just need to unclip the switch arm and snap the new one on.
#7907 10 months ago
Quoted from robey99:
GNR no. Willy Wonka you need the 1.34 Full Install, installed on your game. Then when you turn the game on it sees them.
If you mean the WiFi, yes you need to go into Utilities and connect the game to your router.
#7908 10 months ago
I can’t imagine why they wouldn’t send you a new switch under warranty. That said it seems to be a fairly common issue. Their support said it’s about bending it right and making sure there is enough tension on the springs. Didn’t work for me (would love to see them come up with a solution), I 3D printed a piece that a fellow Pinsider designed to sit on top of where the switch catches, and it’s done the trick.
#7909 10 months ago
Quoted from dergroover:
Yep! The brightness setting on Oompa Loompa multiball is a VERY welcome addition. I can finally track the ball and actually enjoy the mode! Thanks Joe and company!
#7910 10 months ago
Quoted from RobbyIRL5:
Quoted from Yelobird:
Appreciate the help! Just opened a support case with JJP.
#7911 10 months ago
Wifi install went great, bluetooth, not so much.
I bought the ASUS USB-BT400 USB 2.0.. It seems to work, but does not see any of my bluetooth devices other than some random LED strips I have in the game room. I tried, soundbars, headphones.... nothing was found. Curious.
#7912 10 months ago
This is what I put in my Willy Wonka - it works. Shows up on a cellphone too.
https://www.microcenter.com/product/426849/asus-usb-bt400-usb-20-bluetooth-40-adapter
#7913 10 months ago
With new code, I was hoping the game might detect a drain out of the pops and save your ball.
#7914 10 months ago
I’m going to assume this rod is not supposed to be sticking out like this?
#7915 10 months ago
Quoted from Gumby510:
Happened to mine too. Just pushed it back in flush with the flat edge of some small channel locks.
#7916 10 months ago
New code has some nice additions .Noticed a few different callouts and some different lighting effects also. So what do I need to add to my usb to get wifi ? Guess I will need a bluetooth dongle like di uses also.
#7917 10 months ago
Quoted from Kidkoffee:
Thanks I lined it up and it went back in. Also on another note I just updated and now when I start the game it shows these two screens and then will boot into the game normal. What’s going on? Should I reload the update?
24C6000D-3096-485F-AAC7-8A93829F16D7 (resized).jpeg6E9E9C65-A6A8-4B09-97AE-A3E06E08FFD5 (resized).jpeg
#7918 10 months ago
Thanks I lined it up and it went back in. Also on another note I just updated and now when I start the game it shows these two screens and then will boot into the game normal. What’s going on? Should I reload the update? [quoted image][quoted image]
Expected behavior, you're good.
#7919 10 months ago
I have that too.
#7920 10 months ago
I’m a broken record, but I can’t get over how many approaches there are to this game, and how fun and challenging they are. The game is unique and joyful.
#7921 10 months ago
Great game I agree. It’s too bad it isn’t an easy one to find on location and that others haven’t had a chance to get some time in it. I know a lot of locals looking to spend some time over at my place to get more time on it.
Quoted from TheFamilyArcade:
#7922 10 months ago
Has anyone with a recent CE purchase checked their playfield for pooling? I have a few spots (lower slings both upper metal posts, and left lower rail on the outlane). Unlike GnR, the posts do not have any washer (star posts are ok).... the metal also looks like it is at a slight angle. Just curious if anyone else has this and if they have filed a claim w/ JJP?
00F668EA-E6A4-4E18-9BF6-F68CC6B42C93 (resized).jpeg1BD11DA6-85B8-4C9A-935F-B18811B9F5AF (resized).jpeg473045C9-C619-4D5D-ADEF-E670D506914B (resized).jpegB86AB409-EFA0-45B7-A4D5-6054F0F85DE5 (resized).jpegDFBDAA53-727B-4371-8B61-6BEA3E9B5022 (resized).jpeg
#7923 10 months ago
Quoted from Tdavis7965:
[quoted image][quoted image][quoted image][quoted image][quoted image]
No issues here but plus one on some of the best clearest pictures I have seen on Pinside.
#7924 10 months ago
I have heard all they will do is suggest sending you the washers. I find it kind of BS for this kind of money and a known issue.
#7925 10 months ago
I’ve had mine for two weeks and it is bad already have chipping
#7926 10 months ago
Just sent them a message waiting for a reply
#7927 10 months ago
Quoted from Pinman502:
Wow, is this CE? I have done the same... we’re your posts at any angle?
#7928 10 months ago
So now that Wonka has wifi support with the new update, where is the port to add a USB wireless adapter? Does it just reside in the same usb port used for updating or is there a port in the back box? Doubt it already has one but maybe?
#7929 10 months ago
Regular star posts and/or silicon washers will cover most of not all of that clear chipping. Mylar rings also pictured at right...pick your solution
6AFC6992-2A49-4452-84C8-5443B38EA460 (resized).jpegCE2B6128-2331-41BB-A3A3-836225BB91D5 (resized).jpeg
#7930 10 months ago
Quoted from Jeffster:
My Willy Wonka didn't have a spare USB port on the motherboard. So I picked up a USB Hub and plugged the WiFi dongle and Bluetooth dongle into it. And then plugged that into the USB cable by the cashbox.
The USB Hub I picked up had four ports. So if I want to add an image or do a USB update, I can plug it into one of the two spare ports.
#7931 10 months ago
Thanks....guess I'll do the same since I don't have a spare usb port on the motherboard either. Thank you!
#7932 10 months ago
Yes it is the CE my post were straight but I have a lot of clearcoat pooling on both Sling’s
#7933 10 months ago
Quoted from LTG:
This is what I did works great.
#7934 10 months ago
Had the same issues On my Teenage Mutant Ninja Turtles LE Stern just sent me out a non-populated playfield also had chipping on my Deadpool and received a replacement play field for that one as well i’ve bought four new in box machines this year and three of them has had bad play fields for some reason my Jurassic Park premium has not had a single issue
#7935 10 months ago
The cliffy set covers the star posts (carbon fiber rings), but should we be changing out the narrow posts with star posts (as the repair kit for POTC had)?
#7936 10 months ago
Scorbit - so I’m connected, have my venue setup, game added, and now what? Played a game. What (if anything) is Scorbit doing in the background? If I set a high score is there anything I have to do to post or is it automatic?
#7938 10 months ago
tried to download new code ..got error. now game is unplayable
#7939 10 months ago
Quoted from gmanrulz46:
Please start over. Fresh download, there are two mirrors - USA and EU, try the other one than what you used before.
USB stick, 8GB to 16GB with nothing else on it.
#7940 10 months ago
What it does automatically is log plays and scores, some of which you can see (My Machines will show you play counts by day.)
The idea is, when you're playing a game:
- Launch Scorbit
- Hit the center button on the bottom
- Select your venue/game
- Tap the player slot (which change from "Player X" to "You".)
At that point the score for that game will be associated with your Scorbit user and score history.
Unfortunately you have to do this for each game you start.
You can do it mid-game though, I generally do it if I feel a heater coming on.
#7941 10 months ago
Following this... I would think any pooling around the metal posts could be covered and protected with any star post? For me, I have concern if the thread is straight or at an angle in the playfield, maybe not a big issue?
#7942 10 months ago
#7943 10 months ago
Quoted from zaphX:
We have an auto-claim and auto-submit feature in Account Menu > Settings > Playing Preferences. If you set auto-claim, when you play a game with the app and there is only one player on it, it will claim player 1. With auto-submit, when you finish a game, it will automatically save it to the leaderboard.
The app must be open for this automation to work, though. The good news is we're moving auto-submit to the background so the phone can be locked and it will still work (in coming release). However, auto-claim is a form of authentication, so we need to know you're physically there, etc, so the app should be open.
Another feature coming in a release soon is Hog Mode, where you can turn auto-claim and auto-submit on for machines you own in a venue you own, which you turn on once when you press a special button at the start of a game. As long as games are less than 5 minutes apart, it will auto-claim and auto-submit for that machine. If you walk away and grab a beer and come back, it's like a kill switch, Hog Mode needs to be re-activated. This feature does auto-claim in the background, so the phone can go back in your pocket!
This is designed for home use, obviously.
#7944 10 months ago
Quoted from happyclan:
I'm with you! Thanks. Really appreciate it.
Okay, I tested Q324 that leads to the Wonkavator VUK. Looks like a bad transistor. I'm getting 84ohm on the bad one and 10ohm on its neighbors. I'm not sure I'm testing this right but figured going from emitter to receiver was right. I only had one EE class in school and sucked at it.
I noticed a scorching near the transistor leads on the PCB backside. Probably not coincidence.
Everyone, I hope you're seeing this post because I suspect the software update and this event were likely not related on my machine. I'll report back what JJP says. They are such a cool company.
#7945 10 months ago
Good job! I feel like it woudn't be the worst idea for me to have a dozen of those transistors on hand, for eventualities like this.
#7946 10 months ago
I dont have a CE but i found my posts were angled. Then they got worse and i realized they were loose and needed tightening....
#7947 10 months ago
Wow I thought the ce's were good and didn't have playfield issues. This is the first I've seen ce issues posted.
#7949 10 months ago
When updating the code, does it reset the plays of the machine? It does erase all high scores correct?
#7950 10 months ago
Quoted from dsmoke1986:
Back up your settings. ( I always do out of habit )
It should save them. But that doesn't seem to be the case this time.
