(Topic ID: 240130)
Wonka Club - Golden Tickets Inside
By f3honda4me
2 years ago
  • 10,106 posts
  • 541 Pinsiders participating
  • Latest reply 3 hours ago by daveyvandy
  • Topic is favorited by 227 Pinsiders
Topic poll
“What edition are you ordering or planning to buy?”
  • Standard 128 votes
    26%
  • Limited Edition 245 votes
    50%
  • Collectors Edition 114 votes
    23%
(487 votes)
12 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,106 posts in this topic. You are on page 147 of 203.
#7301 10 months ago
Quoted from Yelobird:
It just slides over the top of the stock butter box factory. Tape is added to keep it in place but we designed it to not remove any stock parts. Your stock game should look like this unless something was removed. Good luck.
I was under the impression you had to remove the plastic to the left of the stock factory in order to get the Mezel Mods pipes to fit?
#7302 10 months ago
Quoted from darkryder:
Hey guys, I just brought home a Wonka LE. It came with the Mezel Mods factory with pipes as well as the Mod Couple Factory. I removed the Mezel factory mod and trying to install the Mod Coupe factory, but don’t understand how it mounts. There’s all kinds of interference. I guess I’m missing something...any guidance would be appreciated.[quoted image][quoted image][quoted image][quoted image][quoted image]
My question is how did the previous owner get the Mezel Mods Pipes on with the left stock plastic still in place? I wasnt able to figure this out so I didnt install my Mezel Mod pieces...
#7303 10 months ago
Quoted from Rager170:
I was referring to how to install our factory. Ours goes over the existing box not sure how the Mezel unit goes on sorry.
#7304 10 months ago
Yea, sorry. I deleted my original post once I realized I read it wrong and replied.... sorry about that.
On another note, good design on your part to just cover the existing!
#7305 10 months ago
Hey guys, This is a generic question but I have a Wonka. There is a small part of my side art decal that is not sticking. What can I use to keep it glued? Or reactivate the glue that it had on it. I have to reinstall some pin stadium lights and want to make sure that it is secure before doing so. Thanks.
#7306 10 months ago
Quoted from bsrhardy:
You could try an iron or hair dryer to reactivate the adhesive and press it back. Should work.
#7307 10 months ago
Quoted from Camvr2013:
Created a DropBox folder to house all of my Wonka mods. The Fizzy Lifting Drink label is there for anyone who would like to print one for yourself!
https://www.dropbox.com/sh/hfftfjyycgj2f8i/AABfrtHZyK3YO2OkOvljExCBa?dl=0
Added a 3D printable Wonka Bar to the Dropbox! Have at it!
24C2E510-2ECE-4ABA-B07D-7B17F8BF076A (resized).jpeg9417FF95-6A2B-4DEA-BBB7-F509C9B0985A (resized).jpeg
#7308 10 months ago
EDIT: ALL POSITIONS FILLED. I had a big response to the notice for JJP Tibetan Breeze kit testers and all machine testing slots are already filled. Thanks to all who were willing to jump in and help get these kits available to everyone!
#7309 10 months ago
thanks, this is helpfull as I can printi locally, from Brazil .
#7310 10 months ago
Quoted from PinMonk:
With the details worked out for the JJP Tibetan Breeze flipper cooling kits done and the jjGnR testing almost finished, I need one tester for each of the other JJP games to verify the install works on that machine. With both runs of testing (first without fans, then with the fans) it's about a 4-5 hour commitment total. Each testing pass will take 2 uninterrupted hours (no breaks, etc) to stress test the flipper coils. You'll get a free kit out of the testing.
You'll need to take some install pictures of your kit install and send the worksheet I'll send you filled out with the temps for each flipper in each pass of testing. If you want to be a tester, you need to have time available to complete the testing within a week of getting the parts, since this install check is all that's left before releasing the kits for JJP machines.
If you're in the USA, interested and have the time available for this, PM me with the machine you want to test. jjGnR is done, but WoZ, Hobbit, Dialed In and Wonka are all up for grabs. I plan to get the tester list set this week and will likely be sending out kits next week for testing once the new JJP-specific wiring harnesses arrive from the factory.
I have all 4 of those games and can help if needed
#7311 10 months ago
EDIT: ALL POSITIONS FILLED. I had a big response to the notice for JJP Tibetan Breeze kit testers and all machine testing slots are already filled. Thanks to all who were willing to jump in!
I just got on to post about what I thought was bad flipper fade after about 45-60 mins. Assuming this means I wasn’t imagining it! I’m in when you start making them!
#7312 10 months ago
Quoted from RobbyIRL5:
Wonka uses the second to strongest flipper coils, FL-15411s, and they can fade after about 40 minutes (or less if you trap a lot in your play style). Based on the jjGnR kit testing, the fans solve the problem. 11629s may still just creep a couple degrees past 130F peak when cooled (as opposed to 219.8F uncooled), but for 15411s you'll be easily in the green zone between 115-130 max when cooled.
The GnR kit will probably ship first, then when I've confirmed installs and cooling performance with the other JJP machines with the testers that signed up, it'll be available for all JJP machines using custom wiring harnesses designed for JJP machines. I expect broad availability for all JJP machines by the 2nd or 3rd week of Feb.
#7313 10 months ago
Apologies if this has already been discussed... One of the very first things I noticed about this game was just how dark the backboard was on the playfield. So I set about a solution. Upon doing some other troubleshooting, I realized this game runs off of a pretty standard PC Motherboard(forgive me, this is my first JJP). That meant free USB power! I had a USB LED strip left over from a PC build, so I installed it just above the backboard on the cabinet. Looks and works great and cost me $5.00!!! Woohoo!!!
#7314 10 months ago
My best score by far. Still only 2 golden tickets! This is driving me crazy! In a great pinball way of course!
#7315 10 months ago
My next game! What a day! Probably cursed to a few games of 100,000 now. That still happens frequently.
#7316 10 months ago
Quoted from leaffan67:
Congrats! That’s a really solid score. How long was your game?
#7317 10 months ago
Made these flipper decals tonight! The JJP logo on the top of the flipper makes them a bit wonky, but it still looks better than the flat yellow, in my opinion. So I’ve uploaded the file to my Dropbox link and I HAVE EXTRAS! First 5 people to PM me their address will get them fo’ free!**. I actually used a different design on my personal machine that was a bit derivative and therefore I didn’t feel comfortable sharing that one. So I’d love to see what this design looks like installed on a game!
**If you got a Fizzy Lifting Drink decal, please still feel free to PM me. I will prioritize others first, but if I don’t get a huge response, I will slot you into the list!
#7318 10 months ago
Congrats! That is awesome! I had a killer game 2 days ago for 15 mil. I got the lion's share of the score on Wonka Bar bonuses- Ended up with 596 bars and bonus at max 8X and bonus held.
#7319 10 months ago
Quoted from Krupps4:
it must have been 45 min to an hour. took forever. i was totally engaged as i was trying to get a third ticket via Kid or Wonkavator. i was getting close, but .... same old story. Two tickets.
#7320 10 months ago
Quoted from sgorsuch:
yes, it was during this game that i realized that bonus maxes at 8X. I got a collect bonus for over 2 million points. that helped!
#7321 10 months ago
What are the code or call out differences with the CE vs the LE? I heard the CE has additional call outs and video clips? Would be cool if something like pinbrowser became available for JJPs to unlock unused assets in the game code. I’m enjoying the game so far, but it does get repetitive after a while and more audio and video clips from the movie would have been nice.
#7322 10 months ago
Stock Settings?? If so, fantastic score!!!
#7323 10 months ago
Stock everything except an extra ball for 1 million points. I always have an extra ball replay for some level of points that i find i only hit on occassion.
thx for the congrats!
Wonka is a top 5 game of all time for me. I am truly surprised that i say this because i don't totally love the theme and had never owned a JJP before. Love it!
#7324 10 months ago
Veruca did custom call outs for the CE.
#7325 10 months ago
Great score. It took me a long time to get 10mm... Now I have a goal to meet hahah. I havent been playing much lately but time to get back at it.
#7326 10 months ago
I have a small issue where my headphones only get sound to one ear. A while back people said I just needed to flip the connector inside the cabinet.
Does anyone know which connector that is?
#7327 10 months ago
At the headphone jack board. Turn it around 180 degrees
#7328 10 months ago
Quoted from Pinballomatic:
Yes, but which connector is it to turn 180 degrees?? Or is there only one? Sorry, Im not in front of my machine right now.
#7329 10 months ago
There is just the one from the long harness. Other end plugs into the motherboard.
#7330 10 months ago
Well that makes it easier haha. For some reason I thought there was more than one plugging into the headphone jack board.
Thanks! I will give it a try tonight/.
#7331 10 months ago
Put the glass back on... just kidding, great score.
#7332 10 months ago
My Kickback is missing about 95% of the time. Anyone have an easy fix for this? Doesn't appear to be an alignment issue, but I've been wrong before!
#7333 10 months ago
Either plunger or switch issue. Coils tend to pull the plunger to one side, so think about that when checking alignment. Then concentrate on the switch - closing too soon or too late ?
11
#7334 10 months ago
Hi everyone, just dropping in to say hello as I placed my order for a CE today!! Now the waiting game for delivery, but should be within the next 2 weeks. Feel like I won a Golden Ticket as the Mrs is as excited as I am and she approved the purchase!!
I’ve read all 147 pages over the past few weeks and definitely have a lot to learn. This is my first NIB so I likely will be back with “dumb” questions, but I’ll try searching the forums first.
Of course, overwhelmed by the various mods I’ve seen....
Johnathon
#7335 10 months ago
Quoted from Figment:
Johnathon
Awesome. There are no dumb questions, so ask away. Everyone is here to have a good time and will help you out no sweat!
Congratulations!!!
r/
Mike
#7336 10 months ago
This game is so sweet it’s bursting chocolate at the seams!!! Based on the slime and ooze for GB and TMNT respectively. 3D Print files are in the Dropbox!
#7337 10 months ago
Johnathon
Don't get too caught up in the mods. This is a great game out of the box. In my opinion it does need some extra lighting. Mine came with Pinstadiums. I wouldn't have otherwise paid a premium for what they do, but they work. Check out the Poor Man's Pinstadium thread if you think it's too dark.
#7338 10 months ago
Johnathon
We bought our CE at the beginning of the month and have been enjoying it everyday. Wife has even sneaked off several times to play a game, she's never did that before in the last 28 years of having pins. It's really a love hate relationship with this game, it kicks your a$$ and you just keep going back for more
#7339 10 months ago
Has everybody on here with a CE rated it? Last time I checked it still needed 6 or 7 ratings to be included in the top 100. This pin is amazing, almost missed it because it’s not rated up with the big dogs. So glad I didn’t.
#7340 10 months ago
Thought this beer was fitting.
#7341 10 months ago
Great point! Only 7 more reviews needed to get the CE added into top 100. LE and SE owner reviews have Wonka ranked at 31. Deserves higher in my opinion.
#7342 10 months ago
Quoted from Vabeachrunner4:
Hey all...just picked up a standard and we’re loving it so far! Question about the monitor and if anyone has any recommendations on the “best” settings for it? I know it could be totally subjective but my Wonka LCD looks kind of washed out and not as vibrant as my DILe in comparison. Anyone else notice anything like it?
Were you able to adjust your monitor settings successfully? Mine is in a dark room, so I just dialed down the brightness from 100 to 75, and upped the contrast from 50 to 80. Looks tons better to me now, but I think it will be very room/lighting specific. I didn’t venture in to the advanced adjustments, but would be curious to hear if you or anyone else did. Cheers.
#7343 10 months ago
was thinking about getting a shaker...
Sorry of its been asked a few times but recommended or not that big a deal on this game?
#7344 10 months ago
Quoted from Elvishasleft:
Recommended
#7345 10 months ago
Recommended! The game ramps up the shaker at the start of Wonkavator multi ball and it’s a great effect. I set the shaker strength to high.
#7346 10 months ago
Hell yes recommended. Awesome integration!
#7347 10 months ago
Put in another 2 hours letting Wonka whoop my ass and tapped out. lol How can a game that makes you so happy make you so Mad! Amazing game but as a cute candy kids theme its an ass kicker!
#7348 10 months ago
Wonka made a man out of me, pinball-wise. I was forced to learn better catch skills, nudge skills, and multiball cradling skills.
It is absolutely an ass kicker, but man when you reach the golden ticket goals...such a great payoff!
#7349 10 months ago
Someone in the DeepRoot thread actually posted something along the lines of “with RAZA xtra at $8k, I’m not really seeing $500 of extra value over Wonka SE”.
HaaaaahaaaaaaaahaaaaaahhhhhhaaaaaahhhhhhahahahahahhhhhaaaaahahalollollooolllloolloolloolloololololololololLlluuuullllzzzzzzzzz!
I actually feel bad for people that are missing out on WW because they think it’s a bad them integration or a game for grandmas or whatever. In my top 5 all time and probably higher when it’s all said and done. Chipping playfield and all.
#7350 10 months ago
It’s brutal, for sure. I’ve owned it for a week and still learning the shots and rules. Three golden tickets and 7.5M is my best so far. Factory settings except added extra ball for replay and special and set tilt warnings to max. I nudge a LOT with this game. It definitely keeps me coming back for more!
