(Topic ID: 240130)
Wonka Club - Golden Tickets Inside
By f3honda4me
2 years ago
  • 10,652 posts
  • 560 Pinsiders participating
  • Latest reply 10 hours ago by seenev
  • Topic is favorited by 236 Pinsiders
Topic poll
“What edition are you ordering or planning to buy?”
  • Standard 128 votes
    26%
  • Limited Edition 253 votes
    51%
  • Collectors Edition 116 votes
    23%
(497 votes)
WW autolaunch.pdf (PDF preview)
WW_Rules_Jan20.pdf (PDF preview)
12 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 10,652 posts in this topic. You are on page 107 of 214.
#5301 1 year ago
Quoted from PBMAN:
Hello
Anyone have any idea why I still see the silver part of the monitor. I put in a backglass mod which requires removing the support brackets. However the magnets are so strong you really don’t need the bottom supports
Monitor is even just needs to be lifted about half an inch. I don’t think this monitor has ability to be adjusted vertically.
Also checked to makes sure backglass put back and seated completely.
I added backglass LEDs to brighten the artwork. I also tried removing the support brackets under the monitor per install instructions.
Even with the strong magnets on the monitor, the monitor seems to sag just enough to show it's frame slightly angled through the backglass. For most it may not seem noticeable but for me i couldn't not see the imperfection.
I ended up reinstalling the support brackets and modifying the LED mod strips instead. Monitor is back to its upright normal position w/o showing it's frame thru the backglass.
#5302 1 year ago
Gasoline,
Thanks I tried that. I must be doing something wrong. I know the mod isnt doing it. I going to try removing the entire mod. Supports back on and see if that brings me back to normal. Funny your right for most not noticeable for me it drives me crazy.
#5303 1 year ago
So this just happened... on my Wonka LE, in four out of five games, I would get a random end-of-ball shutdown. That is, I would hit a switch -- any switch -- and my ball would end. In the games that this happened, I had just hit a captive ball (x2), then another time it happened after a Gobstopper bash and the last time I had just finished a run of 6 straight ramps and finished in the saucer (where it happened.)
The ball would hit a switch, the flippers would shut off & the bonus would get awarded. The dead ball would drain and then the next ball would show up in the trough as if nothing happened. Let me be clear: This wasn't a TILT function. The ball was playing normally and something was telling the game it had drained. As I type this, I'm wondering if this could be an opto triggering in the trough? I couldn't find anything of note in the switch tests and I couldn't get it to repeat.
A dirty trough opto maybe?
#5304 1 year ago
Quoted from Ocelot:
Did you go into switch test and see if anything is incorrectly triggering a trough switch?
#5305 1 year ago
Quoted from Ocelot:
Had the same issue, only got worse. In the end I found the trough test sometimes failed and JJP had to replace my boards.
#5306 1 year ago
Just wondering if anyone has any advice on opto switch #006 in the trough staying active sometimes and being inactive other times, pretty sure this is why the game keeps shooting balls into play randomly one after another, any ideas? This is the one that sits a little above the first ball in the trough that has an oval hole instead. I’ve checked the wires and I get the error “all optos active: please check wires and 12V power supply”. Thanks!
#5307 1 year ago
Just posted part two...
#5308 1 year ago
Quoted from Pinash:
Yes and no. I went into the switch tests and scanned for red boxes. Nothing showed up. Since the error seems to happen randomly (it took three games this morning to show up) I'm not sure if it would show up on a switch test. That said, I'm a little over my head with navigating the massive JJP interface so if there's something specifically I should be looking for please let me know.
I performed a trough test with the glass on, firing all six balls into the playfield over and over with no change in the readouts. Is there a smarter way to perform this test for my needs? Thank you.
#5309 1 year ago
Quoted from waldo34:
I know how to perform the trough test but I'm not sure what it's telling me. Is there a way of doing it that pinpointed the problem for you (or JJP)? And, in the end, did you ever find out what corrupted the boards to make it act like this so it didn't happen again or was it just a case of a couple bum boards. Thank you!
#5310 1 year ago
Quoted from Ocelot:
My trough test never showed any red, but it did finally start showing that slot #6 was completely inactive all the time. So if you drained a ball, it wouldn’t register that it was drained and the game would go on as if nothing happened. Then it would go into ball search mode. Very frustrating.
Thankfully JJP sent out two new trough opto boards and now my game is working 100% again.
Hope you get your situation resolved quickly. Sucks having these amazing machines but they don’t work properly....but that’s pinball!
#5311 1 year ago
Quoted from pinpin8990:
Thank you. Yes, that's pinball, indeed. I couldn't be happier with this machine & the experience it delivers -- playing Wonkatania mode with the shaker motor strumming, the lights going nuts and Gene's dialogue creeping incrementally into madness is an example of pinball alchemy that only top-of-their-field creators could implement. I dipped my toe into this hobby 17 years ago but now with code updates, YouTube how-to-videos and most of all, Pinside, I have gone whole hog! Hope all of you are having as much fun as I am with these incredible machines.
#5312 1 year ago
Nice avatar haha
#5313 1 year ago
Quoted from Rager170:
Nice avatar haha
Great minds think alike!
#5314 1 year ago
Part three...
#5315 1 year ago
Finally figured out how to get more points on Wonka's Office! That is a deceptively difficult wizard mode, but if you take the time to read the on screen instructions it all makes sense.
15910308878868070944841091403547 (resized).jpg15910309103316175721590069521918 (resized).jpg
#5316 1 year ago
Excellent, thanks for showing the revised wonkavator.
#5317 1 year ago
Great video. Note: you will probably be fiddling with those thin plastic pieces on the pipe mod for the life of the machine. I love that mod but those were not the best choice... I also ended up leaving all the excess acrylic off and have had no problems. It actually makes that light below a little more prominent which helps.
#5318 1 year ago
Quoted from Adipocere:
Good to know on the acrylic. As for the pipe mod, I haven't had a single issue since I added the tiny bit of super glue. I also lined the plastic tubing with a very thin amount of mounting tape - just enough to keep them snug inside the pipe pieces. Since I've done that, they haven't budged. It's been about 5-6 weeks now with no issues.
#5319 1 year ago
Quoted from jimbodeanny:
That's a decent tip on the tape.
#5320 1 year ago
Quoted from daveyvandy:
[quoted image][quoted image]
Not being a jerk I hope, but how did you get to Wonka’s Office, get almost 900k points and have a total score so low? I have only been to that mode twice and gotten about 190k points at best. Final scores 6.6 and 8.1 million.
Maybe I am getting the points from the multi balls and you didn’t? The one I can’t get many points out of is Oompa Loompa for some reason...
I think the code is genius.
Wonder who the first Pure Imagination champ in the world will be? Surely no one has done it yet?!
#5321 1 year ago
Does anyone else think the slingshots on Wonka feel a little "spongy"? I feel like I read somewhere that they were turned down intentionally, but I can't find the link anywhere. I know the TZ sitting next to it has slings that snap pretty hard (granted, its a Superpin, and there's more room for the ball to move), whereas when they hit in Wonka it feels a little more floaty. If it's intended for the gameplay, then it is what it is.
#5322 1 year ago
Quoted from leaffan67:
I dialed down the difficulty settings from medium to easy. That basically lowers the requirements to get golden tickets. Fewer requirements means fewer points.
Lowering the difficulty doesn't affect the difficulty of the wizard modes though so I'm still happy about my Wonka's Office score. The key was finishing at the Kid Multi-ball target for a 3x jackpot.
I've still only been to pure imagination once and I immediately fudged it and drained. I don't think I would ever get to it with the default normal difficulty settings, but it's my machine and my rules . I find the most secret machine to be my favorite wizard mode anyway.
Oompa Loompa Odyssey is hard for sure, but if you just focus on one ball and go for the hard shots first you can collect the super jackpot for some big payout. Keep in mind you can only collect one jackpot per shot until you get the super (for example: shooting the gobstopper ramp multiple times only gives you the jackpot on the first shot until you complete all shots).
These rules are indeed deep and satisfying.
#5323 1 year ago
I thought it was due to the white rubbers used.
#5324 1 year ago
How does one get to the Most Secret Machine wizard mode?
#5325 1 year ago
Quoted from Noma2017:
Collect 4 golden tickets then shoot the gobstopper.
#5326 1 year ago
Do you need all 4, or do you get it just for collecting the 5 gob ticket?
#5327 1 year ago
Quoted from zaphX:
Ah, thanks. I have only achieved three golden tickets (on easy). Is there a 3rd golden ticket wizard mode?
#5328 1 year ago
Quoted from zaphX:
You need any four golden tickets.
#5329 1 year ago
Well shit I'll never see that.
#5330 1 year ago
Quoted from zaphX:
Exactly why I lowered the difficult lol.
#5331 1 year ago
In for a WWLE and the place I normally by my JJPs have them in stock with production dates around June/July 2019. Now I know there can be issues with the clear. But seeing it had the time to cure for a year I’m not so concerned about it. are there any other things that are different with models build after October 2019 ?
#5332 1 year ago
They may have added some clear plastics on factory ramp to keep ball on factory ramp.And I think they changed the Oompa Loompa tv guy to a different material
#5333 1 year ago
No, you get Wonka's Stash. +50 Candy Jar and +100 Wonka Bars. I've only gotten to Most Secret Machine with the difficulty turned down. It is my favorite mode by far. I wish there was a way to just start the game in that mode and each player just tries to get the highest score on a single ball. The way ball-save is incorporated into that mode works perfectly for this kind of heads up play. Now that I've turned my difficulty back to normal, I never get to see it.
#5334 1 year ago
Quoted from KLR2014:
I wouldn't worry about it. Worst that will happen is you will have some minor pooling at the sling posts. Remove the post, iron the pooling down and add a neoprene washer under the post. You’ll never have an issue again.
#5335 1 year ago
No it's not. I have silicone rubbers on them, the same as on my TZ. The difference is huge on the power of the slings. Wonka's feel sort of lackluster.
#5336 1 year ago
I have played a craptonne (metric) of this game recently. i feel like the slings are the right power. they are a little soft. if they were rocketing the ball around i think it would be a total drainfest. We all know how tough the left outlane is. imagine if you didn't have any time to nudge as it was going 1000 mph over there!
Got my grand champ score today. Love the game. Third time to Wonka's Office. Still not sure if I should be just alternating left and right ramps during this mode?!
Signed,
Previous JJP skeptic.
#5337 1 year ago
Hi All
Couple of things with my Wonka CE-
First- the left loop
When coming out of the pop bumpers the ball rattles around, hits the metal Gobstopper shield on right, bounces over to the left ball guide and that puts it on a direct SDTM trajectory nothing I can do.. really taking the fun out of the game.
Anyone else had this..
2nd - left speaker- sometimes OK, then goes “Tinney” and grainy.
I have heard of this problem before, I’ve taken a look inside the backbox, To try and trace the wires - do I need to take the metal shield off the top part, as that’s where the go..
Any help would be appreciated
#5338 1 year ago
Quoted from Pinhead1982:
Hi All
I had an issue with one of my speakers and had to get a replacement. Unscrew/unbolt the wood piece that holds the grills. Its run across the front. From there, you can get to the speakers. Just be carefull not to let that wood piece fall as the speakers are attached to it. You will need to prop up that piece to disconnect the speakers then you can remove.
Its easy, you will see.
#5339 1 year ago
Well, I made it to Pure Imagination today. Didn’t nerf the game completely, but I did make it easier. Even with the easier settings, it was still a bitch to get to!
Won’t spoil it for anyone, but I have to say I was a bit underwhelmed. Much like Showdown on Dialed In. In the game’s defense, I did totally crap out during the mode. Couldn’t keep the balls alive long enough to do any real damage score wise. But no ball save (at all) is a real kick in the shin.
Going to ramp the difficulty up a little more and try to get it again tomorrow.
This game is just amazing to play!
#5340 1 year ago
What a day. First I get to Pure Imagination for the first time, then while watching my son play tonight I notice my trough start to act up again. Already replaced both opto boards once, and now I’m seeing random balls ejecting for no reason. Didn’t happen much, but for what I paid for this machine, I don’t want it to happen once!
How many of you have had to replace the boards multiple times? Someone please assure me that this will end at some point! Please?!
#5341 1 year ago
Knock on wood, I’ve had no issues with mine.
#5342 1 year ago
Signed,
I agree that the slings are fine from a gameplay perspective. From a mechanical point of vew, they are not very satisfying. Tried adjusting sling power in menu and it didn't seem to make a difference.
#5343 1 year ago
Hi All
Pops down the middle is one of the main drains of the game as designed. On other games, the pops are a relaxing time to take a sip of beer. On this baby, the pops are a time to check your stance and tighten up your core in prep for a meganudge. There was a post awhile back of installing an extra post so the left flipper is always fed from the pops. It sounds like you might like that tweak.
#5344 1 year ago
Quoted from Lrrr:
That's an interesting idea. But does it involve drilling?
#5345 1 year ago
No. There is a nylon plug in front of the existing post. Remove the plug and move the existing post up to it.
#5346 1 year ago
Quoted from LTG:
Oh, I had the impression that someone installed a post around the pop bumpers.
#5347 1 year ago
They did!! Try here:
https://pinside.com/pinball/forum/topic/wwcf-club-wonka-golden-tickets-inside/page/56#post-5246701
I do get the odd sdtm from the pop bumpers, but it doesn't seem >too< extreme for me. Wait until I am one jackpot away from ticket 5 and that happens, I will be singing a different song then...
#5348 1 year ago
I think LTG was mistaken and talking about the post by the left drain.
#5349 1 year ago
Quoted from slippifishi:
Awesome! Thanks for linking that.
#5350 1 year ago
I think that mod is awesome, however, do you feel it changes the game too much from the original intention?
I dont know.
