Hey Troutfarm, I'm sorry you are even considering this. This is a beautiful JD that I spent a lot of time restoring. I took no shortcuts restoring the cab; sanded, minor imperfections repaired, primed, painted, rescreened warning decals, new rails, lockdown bar, coin door, etc. the playfield was in awesome condition to begin with. This was my second JD, I had both the matte version and shiny version of the topper; I prefer the later. The decals are high quality and the colors look amazing.
If TF decides to trade or sell this, someone will be very happy IMO. Good luck whatever you decide to do. The only reason I sold was due to needing more space and getting down to 1 wide body. TZ had a much shorter tenure, so I reluctantly decided to part with JD.
As for Super Game switch, this was never an issue. I hardly played this mode, since I like to earn multi balls. I assume it is a loose connection or possibly an incorrectly soldered wire after my restore. It did not throw errors and everything was illuminated. This has always been a rock solid example, minus the trough error that has now been corrected with new trough boards. The crane and deadworld worked/works flawlessly. My 1st JD was nothing but constant repair, this one was a pleasure to own.
