Looking for a new set of targets for pinbot. Mine are pretty gouged. Not sure if anyone has a set or can point out the best place for me to order a set online.
These
Someone pointed me to these from Marco
http://www.marcospecialties.com/pinball-parts/A-11177
Not sure if those are the right ones.
A-11177 (Yellow)
A-11315-1 (Blue)
A-11315-2 (Green)
A-11315-3 (Red)
A-11315-4 (Orange)
Those are your part numbers. Marco lists them all, but looks like two or three are out of stock. Should be able to search the other vendors by that part number list and see if they're available elsewhere.
Looks like the green and blue ones are tough to find. Open to any leads on those!
Checked the usual haunts, PBR, marco, bay, and fired off a note to Terry at PBL.
If the switch itself is fine, you could always drill the rivet out and just replace the face if PBR has just the plastic faces. Pop rivets look kinda goofy, but not as goofy as looking like someone took a dremel bit across the whole bank of target faces.
Would this one work? I need a blue target also and wasn't sure which one to order. http://www.pinballlife.com/index.php?p=product&id=463
I would buy 5 of the standard color and just rivet new faces on them. I did a search yesterday for all 5 complete and some are OOS in every site I checked.
Quoted from Deez:Would this one work? I need a blue target also and wasn't sure which one to order. http://www.pinballlife.com/index.php?p=product&id=463
Only if you drilled out the rivets and remove the front facing bracket.
I really don't want to get into re-riveting personally. I PM'd chip and will see if I can get his.
Who would have guessed that would be unobtanium!
This page was printed from https://pinside.com/pinball/forum/topic/wtb-pinbot-target-set and we tried optimising it for printing. Some page elements may have been deliberately hidden.
