Aw, that's a pretty tame one. A bit of rework and he's good to go.
The bridge rectifiers were probably good, I'm not sure I would replace but would definitely clean them with alcohol and apply new heat sink compound. I would guess the lamp dimming is due to the condition of the plugs - definitely replace them. Replace the F5 fuse clip, check the others for cracks.
That Pinhead board uses thicker than normal copper - required for high current. The GPE one does as well. There's a good reason these sell out often - they're reliable and well designed. GPE sold the last one earlier this week and will be out for about month -- ran out of bare boards.
If you want to see a board that is a good candidate for replacement - see this pix (thanks John).
Ed
