I am looking for a NOS or solid used drop target assy like this.
http://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=A-14615+
Jim
Jim
This guy (knazzo) may still have one.
http://pinside.com/pinball/forum/topic/wtb-1-bank-drop-target-assembly-a-14615-williams
Hey Jim
Even though this assy might be difficult to find, it can be assembled using its "sub-components". This is the parts listing for A-14615, quantities needed and where the parts may be purchased. (PBL-Pinball Life, BAA-Bay Area Amusements, M-Marco, PSPA-Pinball Spare Parts Aus.) I didn't list suppliers of common washers, screws, nuts et.
Wally
1688: --3 A-14615 1 bank drop target assy 1
1689: ---4 03-8750 tgt-flush 1 PBL
1690: ---4 A-14617 brkt & post assy 1 M
1691: ---4 4408-01119-00 nut 8-32 esn 4
1692: ---4 A-11397 drop tgt stop bkt 1 PBL
1693: ---4 AE-26-1200 coil assy comp 1 PBL
1700: ---4 01-8413 brkt coil mtg 1 M
1701: ---4 03-7066-4 tubing-coil 1 M
1702: ---4 A-11388-2 plunger & reset plate assy 1 M
1705: ----5 4410-01132-01 nut 10-32 esna/ntm 1
1706: ---4 4700-00072-00 fw .265X.500X.032 4
1707: ---4 10-392 spring-extension 1 M
1708: ---4 20-8712-25 e ring 1/4 shaft 2
1709: ---4 01-10183 brkt switch 1 M
1710: ---4 4006-01003-03 ms 6-32X3/16 p-ph-s 4
1711: ---4 4010-01025-14 ms 10-32X7/8 p-rh 1
1712: ---4 10-433 spring-extension 1 M
1713: ---4 5070-09054-00 diode-1N4004 1.0a 1
1714: ---4 5647-12693-31 switch sub mini micro 1 PBL (needs to be cut)
1715: ---4 01-8600 insulator 1 M
1716: ---4 4002-01105-12 ms 2-56 x 3/4 p-ph-s 2
1717: ---4 A-14908 target k/down assy 1 (build from the following 9 parts)
1718: ----5 01-8647-L actuator 1 M
1719: ----5 A-15821 armature sub assy 1 M
1720: ----5 A-14913 frame & eyelet assy 1 PSPA or BAA
1721: ----5 SM1-26-600 coil assy 1 M
1728: ----5 10-363 spring-extension 1 M
1729: ----5 4006-01003-03 ms 6-32X3/16 p-ph-s 2
1730: ----5 4700-00089-00 fw .172X.437X.062 brass 1
1731: ----5 4701-00003-00 lw #8 split 1
1732: ----5 4008-01005-06BRms 8-32x3/8 p-ph-brass 1
1735: ---4 03-8630 guide actuator 1 M
1736: ---4 4700-00003-00 fw .125X.281X.032 4
1737: ---4 4402-01119-00 nut 2-56 esna 2
I found the parts to rebuild mine. Not a easy task and these parts are gone until someone makes more .
This page was printed from https://pinside.com/pinball/forum/topic/wtb-a-14615-drop-target-assy and we tried optimising it for printing. Some page elements may have been deliberately hidden.
